AW: [mapserver-users] Help installing mapserver 4.10.7
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Tue Apr 10 02:55:46 EDT 2012
This file will be auto-created by the build process using flex.
You should be able to directly install it from Red Hat repos via
# yum install flex
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Erica
> Gesendet: Freitag, 6. April 2012 22:00
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] Help installing mapserver 4.10.7
> I'm attempting to install mapserver 4.10.7 on RHEL 5.6
> (kernel 2.6.18-238.35.1.el5).
> Configure works successfully, but I get the following error
> when running make:
> : -Pmsyy -i -omaplexer.c maplexer.l
> gcc -c -O2 -fPIC -Wall -DHAVE_VSNPRINTF -DNEED_STRLCAT
> -DUSE_EPPL -DUSE_JPEG -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG
> -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW
> -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV
> -DUSE_ZLIB -I/usr/include maplexer.c -o maplexer.o
> gcc: maplexer.c: No such file or directory
> gcc: no input files
> make: *** [maplexer.o] Error 1
> maplexer.c does not appear to exist either in the tarball or
> in the branches for 4.10.7. maplexer.o is the only file
> present. Has anybody encountered this before? What's the workaround?
> Thanks.
