[mapserver-users] labels problem
Fernando Norte fernando at globalgeo.com.br
Tue Apr 10 10:24:17 EDT 2012
Hi Karina,
This feature of create tips its more concearn to the interface, like
OpenLayers. The MapServer can be used as WMS to provide the data to this
'tips', but the OpenLayers (or even jQuery) will create the tip and control
the mouse event to open it.  This is a little bit of complex for non
programers, because need JavaScript skills to create it.
Att,
2012/4/10 Karina Guardado <kguardado at gmail.com>
> Hi Fernando,
> Thank you very much for your reply , you know I found the problem and it
> was the .ttf file  so I download another arial.ttf for example and then it
> worked fine.
> I have another question,  is it possible that Mapserver have something
> like the Map tips of Arcgis? or is it related with other software like
> Openlayers for example?
> best regards,
> karina
> On Tue, Apr 10, 2012 at 6:11 AM, Fernando Norte <fernando at globalgeo.com.br
> > wrote:
>> Hi Karina,
>> I need more information about your mapfile and font file to help you, try
>> to paste the code here or use http://pastebin.com/.
>> Try check if had any error in the mapfile, you can view this error just
>> showing the map with mode=map or declare a error log file in the mapfile
>> with: CONFIG "MS_ERRORFILE" "/path/to/file.log"
>> Maybe you not specify the FONT, or another error in mapfile.
>> Att,
>>>  Hi,
>>> I'm having problems with labels on my mapfile, when I use the
>>> parameter TYPE TRUETYPE then I can't see the map but when I erase this
>>> line I can see the map but never see the labels. I have checked the
>>> path to the fonset file and it is ok, also I have verified the .ttf
>>> file corresponding to the font exist. Any idea about this problem, I'm
>>> using mapserver 5.6.5
>>> regards
>>>  Karina Guardado
>>> El Salvador
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120410/55ee8002/attachment.html
