[mapserver-users] labels problem
Karina Guardado
kguardado at gmail.com
Tue Apr 10 10:26:27 EDT 2012
thank you very much Fernando and now it is clear for me.
regards,
On Tue, Apr 10, 2012 at 8:24 AM, Fernando Norte
<fernando at globalgeo.com.br>wrote:
> Hi Karina,
> This feature of create tips its more concearn to the interface, like
> OpenLayers. The MapServer can be used as WMS to provide the data to this
> 'tips', but the OpenLayers (or even jQuery) will create the tip and control
> the mouse event to open it. This is a little bit of complex for non
> programers, because need JavaScript skills to create it.
> Att,
> 2012/4/10 Karina Guardado <kguardado at gmail.com>
>> Hi Fernando,
>> Thank you very much for your reply , you know I found the problem and it
>> was the .ttf file so I download another arial.ttf for example and then it
>> worked fine.
>> I have another question, is it possible that Mapserver have something
>> like the Map tips of Arcgis? or is it related with other software like
>> Openlayers for example?
>> best regards,
>> karina
>> On Tue, Apr 10, 2012 at 6:11 AM, Fernando Norte <
>> fernando at globalgeo.com.br> wrote:
>>> Hi Karina,
>>> I need more information about your mapfile and font file to help you,
>>> try to paste the code here or use http://pastebin.com/.
>>> Try check if had any error in the mapfile, you can view this error just
>>> showing the map with mode=map or declare a error log file in the mapfile
>>> with: CONFIG "MS_ERRORFILE" "/path/to/file.log"
>>> Maybe you not specify the FONT, or another error in mapfile.
>>> Att,
>>>> Hi,
>>>> I'm having problems with labels on my mapfile, when I use the
>>>> parameter TYPE TRUETYPE then I can't see the map but when I erase this
>>>> line I can see the map but never see the labels. I have checked the
>>>> path to the fonset file and it is ok, also I have verified the .ttf
>>>> file corresponding to the font exist. Any idea about this problem, I'm
>>>> using mapserver 5.6.5
>>>> regards
>>>> Karina Guardado
>>>> El Salvador
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
M.Sc. Karina Guardado
Celular: (503) 7115 2898
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120410/2e137de2/attachment-0001.html
