[mapserver-users] Re: pdf vector output in 6.02
frequens
frequens at gmail.com
Mon Apr 23 03:44:31 EDT 2012
Thanks, so it looks like overall trouble...not that it solves my problem
To add, I get no 500 errors in 6.0.2, mapserv/mapscript
Also svg's get created, yet only have a png image inserted, no vectors.
BR
frequens
> BR
> frequens
> On Mon, Apr 23, 2012 at 9:17 AM, Rahkonen Jukka
> <Jukka.Rahkonen at mmmtike.fi> wrote:
>> Hi,
>> PDF output works for me on Windows (MS4W) but I seem to have problems with Linux and Mapserver 6.0.1 also. This one gives HTTP 500 Internal error message and on the server side there seems to occur a segfault
>> http://188.64.1.61/cgi-bin/osm-mapserver_i?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=469&HEIGHT=354&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX=385063.18278820685,6671589.90189085,385461.47239845013,6671890.529869583&SRS=EPSG:3067&STYLES=
>> Same with SVG output. Png etc. works fine. I have the same outputformat as you.
>> -Jukka Rahkonen-
>> frequens wrote:
>>> Weird.To add a little:
>>> With 5.6.5 I am able to get a vector pdf using mapserv or shp2img,
>>> mapscript dies without message.
>>> With 6.0.2 in all three cases (shp2img, mapserv, mapscript) the pdf
>>> gets created, yet contains only the rendered raster image of the
>>> vector layers.
>>> Why this fallback to raster rendering, is this something supposed to
>>> happen? All the underlying libraries are the same.
>>> Any hints?
>>> BR
>>> frequens
>>> On Fri, Apr 20, 2012 at 11:50 PM, frequens <frequens at gmail.com> wrote:
>>> > Hi all,
>>> > I am having trouble producing a high quality vector output pdf with
>>> > 6.02 php mapscript (same trouble using shp2img)
>>> > Cairo is enabled, the pdf file even gets created, but
>>> contains only a
>>> > raster image?
>>> > Pdf output is enabled:
>>> > IMAGETYPE PDF
>>> > and
>>> > OUTPUTFORMAT
>>> > NAME "pdf"
>>> > DRIVER CAIRO/PDF
>>> > MIMETYPE "application/x-pdf"
>>> > IMAGEMODE RGB
>>> > EXTENSION "pdf"
>>> > END
>>> > Since the mapserver documentation on pdf creation is rather archaic,
>>> > any help (a stripped version of someone's mapfile?) would be
>>> > appreciated!
>>> > My cairo library is rather old also: 1.4.10. Might this
>>> have any influence?
>>> > Many thanks in advance,
>>> > frequens
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
