[mapserver-users] Reclassify raster cell values
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Sat Dec 15 01:12:23 PST 2012
Perhaps you just do it somehow wrong. Show your PROCESSING line and try meanwhile something like
PROCESSING "LUT=0:255,1:1,255:255"
I haven't tried it myself, this is mostly a guess.
-Jukka Rahkonen-
Lähettäjä: ALT SHN [i.geografica at alt-shn.org]
Lähetetty: 15. joulukuuta 2012 0:48
Vastaanottaja: Rahkonen Jukka
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] Reclassify raster cell values
Thank you Rahknonen,
However this is not quite what I expected. If I reclassify a particular value, all other cells disapear.
This leads me to another question (I'll open another topic too). the PROCESSING LUT command can be used as a way to build a indexed color table for 8bit rasters. Is there a way to import a color table ?
Thank you
André
2012/12/10 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi<mailto:Jukka.Rahkonen at mmmtike.fi>>
It should be possible to do what you want by using the PROCESSING LUT option.
http://www.mapserver.org/input/raster.html
-Jukka Rahkonen-
> ALT SHN wrote:
> Hello Everyone,
> First time Mapserver user here, and I would appreciate some advice regarding this problem:
> I have a Tile Index of single band TIFF rasters (0-255). The rasters are displayer fast, and accuratly. However these rasters cover a sea shore area, this means that half the rasters are sea territory, wich is represented in black (0 cell values)
> Is there way, in the Mapfile to reclassify the 0 cells to 255 in order to turn them white? I know I can always pre process the rasters, but I'm talking about forty + files...
> Thanks in advance,
Cheers,
André Mano
Associação Leonel Trindade
SOCIEDADE DE HISTÓRIA NATURAL
Apartado 25 2564-909 Torres Vedras Portugal
Sede e Biblioteca: rua Cavaleiros da Espora Dourada, 27A 2560 Torres Vedras
Laboratório de Paleontologia e Paleoecologia: Polígono Industrial do Alto do Ameal 2565-641 Ramalhal
http://alt-shn.blogspot.com
www.alt-shn.org<http://www.alt-shn.org><http://www.alt-shn.org>
