[mapserver-users] PostGIS Connection String - Thread Issue?
Trent Pingenot
pintj at hotmail.com
Thu Feb 2 17:00:53 EST 2012
Hi list,
We recently upgraded from MapServer 5.x to 6.0.1 on Linux. We have 21 sites running all running smoothly with identical configurations off this server. On one site the MapServer connection to Postgres/PostGIS fails on all layers. The MS debug message is as follows
[Thu Feb 2 14:41:04 2012].823297 msPostGISLayerOpen(): Query error. Database connection failed (FATAL: no pg_hba.conf entry for host "[local]", user "interlocken", database "nterlocNken", SSL off
) with connect string 'dbname='nterlocNken' user='interlocken' password=*******************'
And the entry in the map file
CONNECTIONTYPE postgis
PROCESSING "CLOSE_CONNECTION=DEFER"
CONNECTION "dbname='interlocken' user='interlocken' password='**************'"
DATA 'the_geom FROM "ext_lighting_existing_point" USING UNIQUE gid USING srid=4326'
I can log into psql on the server as the interlocken user and hit the DB just fine so it's not the pg_hba.conf file settings which are set that the db username and db name must match. My question is why
does the dbname get corrupted to nterlocNken? Is this a bug or how mapserver should present the connection items in a debug statement? I can use our old copy 5.4 copy of mapserver and it runs the map file fine. One difference in this build is that we don't have the --with-threads support. We are looking at getting the build rebuilt with this thread locking option included. Could threading be the problem? I'm not sure how/if threading might be related but thought I would mention it.
I've stripped out all layers from the mapfile except a single test layer. I've got 60+ layers running in other map files and databases with identical setups on the same server without problems, why this one? We even tried wiping out the DB and associated user and reloading and still the same problem.
Thanks in advance for any help or tips you can provide.
Thanks,
Trent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120202/835370da/attachment.html
