[mapserver-users] PostGIS Connection String - Thread Issue?
thomas bonfort
thomas.bonfort at gmail.com
Fri Feb 3 11:18:39 EST 2012
Trent,
can you file a ticket for this issue please?
regards,
thomas
On Fri, Feb 3, 2012 at 17:16, Trent Pingenot <pintj at hotmail.com> wrote:
> Thomas,
> That did it! I had tried removing the single quotes from the username, but
> not the db, but not both, I can't remember. By removing single quotes around
> both the dbname and the username it started working. It's still strange to
> me that it works with single quotes on all my other sites.
> Thanks for your suggestion!
> Trent
>> Date: Fri, 3 Feb 2012 09:33:15 +0100
>> Subject: Re: [mapserver-users] PostGIS Connection String - Thread Issue?
>> From: thomas.bonfort at gmail.com
>> To: pintj at hotmail.com
>> CC: mapserver-users at lists.osgeo.org
>> There were some changes to string quoting/escaping in version 6 (I think).
>> Are the errors you are seeing intermittent, or is it reproducible
>> consistently on all requests?
>> What happens if you use
>> CONNECTION "dbname=interlocken user=interlocken ..."
>> instead of
>> CONNECTION "dbname='interlocken' user='interlocken' ..."
>> thomas
>> On Thu, Feb 2, 2012 at 23:00, Trent Pingenot <pintj at hotmail.com> wrote:
>> > Hi list,
>> > We recently upgraded from MapServer 5.x to 6.0.1 on Linux. We have 21
>> > sites
>> > running all running smoothly with identical configurations off this
>> > server.
>> > On one site the MapServer connection to Postgres/PostGIS fails on all
>> > layers. The MS debug message is as follows
>> > [Thu Feb 2 14:41:04 2012].823297 msPostGISLayerOpen(): Query error.
>> > Database connection failed (FATAL: no pg_hba.conf entry for host
>> > "[local]",
>> > user "interlocken", database "nterlocNken", SSL off
>> > ) with connect string 'dbname='nterlocNken' user='interlocken'
>> > password=*******************'
>> > And the entry in the map file
>> > CONNECTIONTYPE postgis
>> > PROCESSING "CLOSE_CONNECTION=DEFER"
>> > password='**************'"
>> > DATA 'the_geom FROM "ext_lighting_existing_point" USING UNIQUE gid USING
>> > srid=4326'
>> > I can log into psql on the server as the interlocken user and hit the DB
>> > just fine so it's not the pg_hba.conf file settings which are set that
>> > the
>> > db username and db name must match. My question is why
>> > does the dbname get corrupted to nterlocNken? Is this a bug or how
>> > mapserver
>> > should present the connection items in a debug statement? I can use our
>> > old
>> > copy 5.4 copy of mapserver and it runs the map file fine. One
>> > difference in
>> > this build is that we don't have the --with-threads support. We are
>> > looking
>> > at getting the build rebuilt with this thread locking option included.
>> > Could threading be the problem? I'm not sure how/if threading might be
>> > related but thought I would mention it.
>> > I've stripped out all layers from the mapfile except a single test
>> > layer.
>> > I've got 60+ layers running in other map files and databases with
>> > identical
>> > setups on the same server without problems, why this one? We even
>> > tried
>> > wiping out the DB and associated user and reloading and still the same
>> > problem.
>> > Thanks in advance for any help or tips you can provide.
>> > Thanks,
>> > Trent
>> > _______________________________________________
>> > mapserver-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
