[mapserver-users] Mapserver + PostGIS ==> Blank Screen
cheryl buckley
cheryl.bckl at gmail.com
Sun Feb 12 17:06:48 EST 2012
Hi Brent,
Thanks for your reply.
The SRS my data is stored in WGS84.
Unfortunately, I am not getting configuration file right. I adjusted the
map EXTENT to something smaller,
Map
Extent 16 -28 25 -16
The layer extent I also adjusted to the output image of the contour data,
Layer
Extent 17.002 -20.965 18.007 -20.002
I played around with the figures a little but I get this error message at
all times,
"msDrawMap(): Image handling error. Failed to draw layer named 'Contour'.
msPostGISLayerWhichShapes(): Query error. Error (ERROR: function
geomfromtext(unknown, integer) does not exist LINE 1: ...R'),'hex') as
geom,"gid" from atest where geom && GeomFromTe... ^ HINT: No function
matches the given name and argument types. You might need to add explicit
type casts. ) executing query: select
encode(ST_AsBinary(ST_Force_2D("geom"),'NDR'),'hex') as geom,"gid" from
atest where geom && GeomFromText('POLYGON((15.8348164627364
-28,15.8348164627364 -16,25.1651835372636 -16,25.1651835372636
-28,15.8348164627364 -28))',4326)"
Since this is my first time configurating a mapfile, I am unsure of what is
essential and what not, thus, I copied and pasted the script and adjusted
it to my CONNECTION details. I am not too sure whether it is vital to have
both a "map extent" and a "layer extend"?
Do you perhaps have any hints in this regard?
Best Regards
Cheryl
On Sun, Feb 12, 2012 at 6:49 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
> Cherly,
> One issue could be that you've asked Mapserver to render the entire world:
> EXTENT -90 -180 90 180
> into a small image:
> mapsize=600+800
> Adjust the extents of the output image to be the extent of you contour
> data. I see that you've given that in your LAYER definition
> EXTENT 143 -20 145 -19
> so try that for the map extent (but I think it would be valid only if the
> contours were stored in a Geographic system and not a Projected system).
> What SRS are you storing your data in? The same as your display
> (EPSG:4326)?
> Best Regards,
> Brent Fraser
> On 2/12/2012 9:43 AM, cheryl buckley wrote:
>> Hi,
>> I'm trying to get Mapserver connected with PostGIS. PostGIS is holding
>> a shape2pgsql contourline import in the table "atest" while a test has
>> the following columns (shape2pgsql default):
>> | Actions | gid | id | height | geom |
>> Quantum GIS picks the conection up perfectly to atest but with
>> Mapserver I just get a blank screen - or the color of IMAGECOLOR [. .
>> .] definition in test-2.map definitions.
>> Somehow it seems like I got the connection between Mapserver and
>> PostGIS running - at least the debug.log doesn't complain. But still
>> I'm not seeing any of my contour lines as I'm used to by Quantum GIS
>> Could someone give me a hint of what I'm missing out or where my mistake
>> is?
>> I got the feeling that it is either has something to do with the DATA
>> property or the projection properties …
>> The Link with which I call the mapserv binary is:
>> http://192.168.10.15/cgi-bin/**mapserv?map=./Maps/test.map&**mode=map<http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map>
>> But then it complains:
>> msDrawMap(): Image handling error. Unable to initialize image.
>> msPrepareImage(): General error message. Image dimensions not
>> specified. msCalculateScale(): General error message. Invalid image
>> width or height.
>> So I changed it to the following:
>> mode=map&mapsize=600+800<http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map&mapsize=600+800>
>> which results in no errors but therefore in a blank screen with a
>> clean debug.log ...
>> Even this one wont change anything:
>> mode=map&mapsize=600+800&**layer=Contour<http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map&mapsize=600+800&layer=Contour>
>> . . . my test-2.map definition is below:
>> P.S.: TEMPLATE "./Maps/test.map" does exist and is read and writeable
>> to the user which runs the webserver (Apache => User: www)
>> CONFIG "PROJ_LIB" "/usr/local/share/proj/" should also be valid:
>> FreeBSD [~]# ls /usr/local/share/proj
>> FL WO hawaii
>> null stlrnc
>> GL27 alaska nad.lst
>> nzgd2kgrid0005.gsb stpaul
>> IGNF conus nad27 other.extra
>> world
>> MD epsg nad83
>> proj_def.dat
>> TN esri ntf_r93.gsb
>> prvi
>> WI esri.extra ntv1_can.dat
>> stgeorge
>> # ==============================**===== test-2.map
>> MAP
>> CONFIG "MS_ERRORFILE" "./debug.log"
>> DEBUG 5
>> IMAGECOLOR 100 100 100
>> NAME "Contour"
>> STATUS ON
>> PROJECTION
>> "init=epsg:4326"
>> END
>> WEB
>> METADATA
>> WMS_NAME "Contour"
>> WMS_TITLE "SRTM - ContourLines"
>> WMS_ABSTRACT "My First Web Map Server"
>> WMS_SERVER_VERSION "1.1.1"
>> WMS_SRS "EPSG:4326"
>> WMS_ONLINERESOURCE
>> "http://192.168.10.15/cgi-bin/**mapserv?map=./Maps/test.map<http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map>
>> WMS_ATTRIBUTION_TITLE "Some Attribute Title"
>> WMS_ATTRIBUTION_ONLINERESOURCE "http://www.myHomepage.com/"
>> WMS_KEYWORDLIST
>> "DEM,SRTM,Contourlines,**Contour,Lines,Digital,Area,**Model"
>> WMS_FEATURE_INFO_MIME_TYPE "text/html"
>> WMS_**CONTACTELECTRONICMAILADDRESS "User at Domain.tld"
>> WMS_CONTACTPERSON "Some Reference Person"
>> WMS_CONTACTVOICETELEPHONE "+49-phoneNumber"
>> WMS_CONTACTORGANIZATION "Private"
>> WMS_ENCODING "utf-8"
>> END
>> END
>> LAYER # query layer from PostgreSQL table
>> NAME "Contour"
>> TYPE LINE
>> STATUS ON
>> DEBUG ON
>> DUMP true
>> METADATA
>> WMS_NAME "Contour"
>> WMS_TITLE "Contour Lines - 90m"
>> WMS_ABSTRACT "Contour Lines - 90m"
>> WMS_SRS "EPSG:4326"
>> GML_INCLUDE_ITEMS "all"
>> END
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "host=192.168.10.15 port=5432
>> dbname=my_spatial_db user=admin password=******"
>> DATA "geom FROM atest using unique gid using
>> srid=4326"
>> CLASS
>> STYLE
>> COLOR 000 000 000
>> OUTLINECOLOR 199 199 199
>> END
>> END
>> END
>> END
>> # ==============================**===== debug.log
>> FreeBSD [/usr/local/www/cgi-bin/Maps]# cat ./debug.log
>> [Sat Feb 11 19:02:01 2012].3032 CGI Request 1 on process 2663
>> [Sat Feb 11 19:02:01 2012].10325 msDrawMap(): rendering using
>> outputformat named png (AGG/PNG).
>> [Sat Feb 11 19:02:01 2012].10365 msDrawMap(): WMS/WFS set-up and query,
>> 0.000s
>> [Sat Feb 11 19:02:01 2012].10388 msDrawMap(): Drawing Label Cache, 0.000s
>> [Sat Feb 11 19:02:01 2012].10398 msDrawMap() total time: 0.007s
>> [Sat Feb 11 19:02:01 2012].76893 msSaveImage(stdout) total time: 0.066s
>> [Sat Feb 11 19:02:01 2012].77721 mapserv request processing time
>> (loadmap not incl.): 0.075s
>> [Sat Feb 11 19:02:01 2012].77749 msFreeMap(): freeing map at 0x29879800.
>> [Sat Feb 11 19:02:01 2012].77839 msPostGISLayerIsOpen called.
>> ______________________________**_________________
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.**org <mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/**mailman/listinfo/mapserver-**users<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
Greetings
Cheryl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120212/c6aff3ce/attachment-0001.html
