[mapserver-users] Mapserver + PostGIS ==> Blank Screen
Brent Fraser
bfraser at geoanalytic.com
Sun Feb 12 19:10:35 EST 2012
Yikes! That looks like a compatibility problem. PostGIS has been
changing their function names (e.g. from "GeomFromText" to
"ST_GeomFromText"), and I don't think Mapserver has kept up. Can you
use an older version of PostGIS (<2.0)?
http://postgis.refractions.net/pipermail/postgis-devel/2012-January/017272.html
Best Regards,
Brent Fraser
On 2/12/2012 3:06 PM, cheryl buckley wrote:
> Hi Brent,
> Thanks for your reply.
> The SRS my data is stored in WGS84.
> Unfortunately, I am not getting configuration file right. I adjusted
> the map EXTENT to something smaller,
> Map
> Extent 16 -28 25 -16
> The layer extent I also adjusted to the output image of the contour data,
> Layer
> Extent 17.002 -20.965 18.007 -20.002
> I played around with the figures a little but I get this error message
> at all times,
> "msDrawMap(): Image handling error. Failed to draw layer named
> 'Contour'. msPostGISLayerWhichShapes(): Query error. Error (ERROR:
> function geomfromtext(unknown, integer) does not exist LINE 1:
> ...R'),'hex') as geom,"gid" from atest where geom && GeomFromTe... ^
> HINT: No function matches the given name and argument types. You might
> need to add explicit type casts. ) executing query: select
> encode(ST_AsBinary(ST_Force_2D("geom"),'NDR'),'hex') as geom,"gid"
> from atest where geom && GeomFromText('POLYGON((15.8348164627364
> -28,15.8348164627364 -16,25.1651835372636 -16,25.1651835372636
> -28,15.8348164627364 -28))',4326)"
> Since this is my first time configurating a mapfile, I am unsure of
> what is essential and what not, thus, I copied and pasted the script
> and adjusted it to my CONNECTION details. I am not too sure whether it
> is vital to have both a "map extent" and a "layer extend"?
> Do you perhaps have any hints in this regard?
> Best Regards
> Cheryl
> On Sun, Feb 12, 2012 at 6:49 PM, Brent Fraser <bfraser at geoanalytic.com
> <mailto:bfraser at geoanalytic.com>> wrote:
> Cherly,
> One issue could be that you've asked Mapserver to render the
> entire world:
> EXTENT -90 -180 90 180 <tel:90%20-180%2090%20180>
> into a small image:
> mapsize=600+800
> Adjust the extents of the output image to be the extent of you
> contour data. I see that you've given that in your LAYER definition
> EXTENT 143 -20 145 -19
> so try that for the map extent (but I think it would be valid only
> if the contours were stored in a Geographic system and not a
> Projected system). What SRS are you storing your data in? The
> same as your display (EPSG:4326)?
> Best Regards,
> Brent Fraser
> On 2/12/2012 9:43 AM, cheryl buckley wrote:
> Hi,
> I'm trying to get Mapserver connected with PostGIS. PostGIS is
> holding
> a shape2pgsql contourline import in the table "atest" while a
> test has
> the following columns (shape2pgsql default):
> | Actions | gid | id | height | geom |
> Quantum GIS picks the conection up perfectly to atest but with
> Mapserver I just get a blank screen - or the color of
> IMAGECOLOR [. .
> .] definition in test-2.map definitions.
> Somehow it seems like I got the connection between Mapserver and
> PostGIS running - at least the debug.log doesn't complain. But
> still
> I'm not seeing any of my contour lines as I'm used to by
> Quantum GIS
> Could someone give me a hint of what I'm missing out or where
> my mistake is?
> I got the feeling that it is either has something to do with
> the DATA
> property or the projection properties …
> The Link with which I call the mapserv binary is:
> http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map
> <http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map>
> But then it complains:
> msDrawMap(): Image handling error. Unable to initialize image.
> msPrepareImage(): General error message. Image dimensions not
> specified. msCalculateScale(): General error message. Invalid
> image
> width or height.
> So I changed it to the following:
> http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map&mapsize=600+800
> <http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map&mapsize=600+800>
> which results in no errors but therefore in a blank screen with a
> clean debug.log ...
> Even this one wont change anything:
> http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map&mapsize=600+800&layer=Contour
> <http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map&mapsize=600+800&layer=Contour>
> . . . my test-2.map definition is below:
> P.S.: TEMPLATE "./Maps/test.map" does exist and is read and
> writeable
> to the user which runs the webserver (Apache => User: www)
> CONFIG "PROJ_LIB" "/usr/local/share/proj/" should also be valid:
> FreeBSD [~]# ls /usr/local/share/proj
> FL WO hawaii
> null stlrnc
> GL27 alaska nad.lst
> nzgd2kgrid0005.gsb stpaul
> IGNF conus nad27
> other.extra world
> MD epsg nad83
> proj_def.dat
> TN esri ntf_r93.gsb
> prvi
> WI esri.extra ntv1_can.dat
> stgeorge
> # =================================== test-2.map
> MAP
> CONFIG "MS_ERRORFILE" "./debug.log"
> DEBUG 5
> IMAGECOLOR 100 100 100
> NAME "Contour"
> STATUS ON
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> WMS_NAME "Contour"
> WMS_TITLE "SRTM - ContourLines"
> WMS_ABSTRACT "My First Web Map
> Server"
> WMS_SERVER_VERSION "1.1.1"
> WMS_SRS "EPSG:4326"
> WMS_ONLINERESOURCE
> "http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map"
> WMS_ATTRIBUTION_TITLE "Some Attribute
> Title"
> WMS_ATTRIBUTION_ONLINERESOURCE
> "http://www.myHomepage.com/"
> WMS_KEYWORDLIST
> "DEM,SRTM,Contourlines,Contour,Lines,Digital,Area,Model"
> WMS_FEATURE_INFO_MIME_TYPE "text/html"
> WMS_CONTACTELECTRONICMAILADDRESS "User at Domain.tld"
> WMS_CONTACTPERSON "Some Reference
> Person"
> WMS_CONTACTVOICETELEPHONE "+49-phoneNumber"
> WMS_CONTACTORGANIZATION "Private"
> WMS_ENCODING "utf-8"
> END
> END
> LAYER # query layer from PostgreSQL table
> NAME "Contour"
> TYPE LINE
> STATUS ON
> DEBUG ON
> DUMP true
> METADATA
> WMS_NAME "Contour"
> WMS_TITLE "Contour Lines - 90m"
> WMS_ABSTRACT "Contour Lines - 90m"
> WMS_SRS "EPSG:4326"
> GML_INCLUDE_ITEMS "all"
> END
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=192.168.10.15 port=5432
> dbname=my_spatial_db user=admin password=******"
> DATA "geom FROM atest using unique gid
> using srid=4326"
> CLASS
> STYLE
> COLOR 000 000 000
> OUTLINECOLOR 199 199 199
> END
> END
> END
> END
> # =================================== debug.log
> FreeBSD [/usr/local/www/cgi-bin/Maps]# cat ./debug.log
> [Sat Feb 11 19:02:01 2012].3032 CGI Request 1 on process 2663
> [Sat Feb 11 19:02:01 2012].10325 msDrawMap(): rendering using
> outputformat named png (AGG/PNG).
> [Sat Feb 11 19:02:01 2012].10365 msDrawMap(): WMS/WFS set-up
> and query, 0.000s
> [Sat Feb 11 19:02:01 2012].10388 msDrawMap(): Drawing Label
> Cache, 0.000s
> [Sat Feb 11 19:02:01 2012].10398 msDrawMap() total time: 0.007s
> [Sat Feb 11 19:02:01 2012].76893 msSaveImage(stdout) total
> time: 0.066s
> [Sat Feb 11 19:02:01 2012].77721 mapserv request processing time
> (loadmap not incl.): 0.075s
> [Sat Feb 11 19:02:01 2012].77749 msFreeMap(): freeing map at
> 0x29879800.
> [Sat Feb 11 19:02:01 2012].77839 msPostGISLayerIsOpen called.
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> Greetings
> Cheryl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120212/119cae26/attachment.html
