[mapserver-users] Layers flattened
    Juan Jesús Cremades Monserrat
    relicary at gmail.com
    Mon Feb 20 03:49:53 PST 2012
I have a map with several layers. But when the result is rendered in the
browser with OpenLayers, the maps are flattened and all request are done
with the SRS parameter which value EPSG:4326 instead EPSG:23030. Some help?
Thanks!
My MAPFILE is this:
MAP
  PROJECTION
    "init=epsg:23030"
  END
  WEB
    METADATA
      "wms_encoding" "UTF-8"
      "wms_title" "Mapserver WMS"
      "wms_abstract" ""
      "wms_srs" "EPSG:23030 EPSG:4326"
      "wms_onlineresource" "
http://localhost:80/cgi-bin/mapserv.exe?map=MYMAP"
      "ows_enable_request" "*"
      "wms_feature_info_mime_type" "text/html"
    END
  END
  LAYER
    NAME "file.shp"
    STATUS ON
    TYPE POLYGON
    DUMP true
    TEMPLATE "templates/tempalte.html"
    DATA "E:\file.shp"
    MAXSCALE -1.0
    MINSCALE -1.0
    TRANSPARENCY 100
    SIZEUNITS meters
    CLASS
      STYLE
        COLOR 153 153 255
        OUTLINECOLOR 51 51 255
        WIDTH 1
      END
      NAME "default"
    END
    METADATA
      "wms_title" "file.shp"
      "wms_extent" "626679.4375 4191039.75 797868.9375 4519396.0"
      "gml_include_items" "MONO"
      WMS_SRS "EPSG:23030"
    END
  END # Layer
All the layers are similar, and the JS wich showsd the result is like this:
var options = {
controls : [new OpenLayers.Control()],
minExtent : new OpenLayers.Bounds(-1, -1, 1, 1),
maxResolution : 0.35,
maxZoomLevel : 10,
maxExtent : new OpenLayers.Bounds(-1.53544921875, 37.81, 0.0000, 40.84),
zoom: 4,
tileSize : new OpenLayers.Size(400, 550)
map = new OpenLayers.Map('olmap', options);
var ProvinciasWms =
new OpenLayers.Layer.WMS(
"Layer_1",
"/mapserver?",
{layers : 'file.shp',
 format : 'image/png',
 transparent : true,
 map : 'MYMAP'},
{isBaseLayer : false,
 singleTile:true,
 ratio: 1});
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120220/bc075ba2/attachment.htm>
More information about the MapServer-users
