[mapserver-users] Constraining label position
Jan Hartmann
j.l.h.hartmann at uva.nl
Mon Feb 20 09:27:24 EST 2012
On 02/14/2012 06:17 PM, Stephen Woodbridge wrote:
> google: mapserver geomtransform
> this will let you fix the label point to the centroid of the object or
> some other positions.
> The issue is that the label point is generally calculated based on the
> geometry of the object as clipped to the view port. So the geometry
> changes based on the view clipping and this causes the label point to
> also change. the geomtransform works on the original data and so the
> label point becomes fixed.
No I can't get this to work, perhaps I don't understand the syntax of
geomtransform. Can you give me an example of fixing a label to the
center point of a rectangle, without shifting it when the rectangle
crosses the viewport? My mapfile looks:
connectiontype postgis
connection ""
data the_rect from bnds
labelitem rect_id
style
color 0 0 0
end
label
color 0 0 255
end
I put a few geotransforms within the label and within the style objects,
but the label always shifts near the margin of the viewport.
Thanks,
Jan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120220/c92e4b22/attachment.html
