[mapserver-users] Aligning labels within a polygon
Jan Hartmann
j.l.h.hartmann at uva.nl
Tue Feb 21 12:17:49 EST 2012
Going a step further:
st_longestline(st_collect(the_geom),st_collect(the_geom))
gives the longest line segment that can be drawn within the cluster of
street address points. Works for non-curved streets. I'm still looking
for a more intelligent way to thin out a polygon to a (multi)line.
Jan
On 02/21/2012 05:27 PM, Fawcett, David (MPCA) wrote:
> If you are storing the data in PostGIS, you could possibly take
> advantage of ST_Azimuth(). http://www.postgis.org/docs/ST_Azimuth.html
> It takes two point objects as the args, but you could potentially use
> the start and end points of your linestring.
> David.
> *From:*mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Jan
> Hartmann
> *Sent:* Tuesday, February 21, 2012 10:23 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Aligning labels within a polygon
> Hi,
> I'm inputting lots of street address points in PostGIS, and try to
> generate labels for the streets. The convex hull of the points of a
> street approximate the course of the street, and I would like to
> position the streetname in the middle of the convex hull polygon,
> aligned to its dominant angle (the polygons are generally quite
> narrow). Is there a way of doing this with MapServer? Perhaps by
> thinning out the polygon to a line, for then I can use "angle follow".
> Jan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120221/5a8c837b/attachment.html
