[mapserver-users] Aligning labels within a polygon
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Tue Feb 21 14:19:53 EST 2012
Several years ago, I wrote some Python code to roughly georeference air photos. As part of that, I needed to come up with the best approximation of the heading of the airplane.
What worked pretty well was to do a really simple line fitting based on the points. My samples were points from an airplane that was attempting to fly in a straight line, with vertices generated by a camera taking pictures at regular intervals, so that helped.
I simply split the vertices of the line into three groups by dividing the total number of points by 3. I averaged the x and y values in each group and then created a line from the average coord from group1 to the average coord from group3.
Street data will likely be more variable (curved), but you may want to explore something like this. Of course, you would likely want to calculate these label angles using pre-processing to speed up rendering time.
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jan Hartmann
Sent: Tuesday, February 21, 2012 11:18 AM
To: Fawcett, David (MPCA)
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Aligning labels within a polygon
Going a step further:
st_longestline(st_collect(the_geom),st_collect(the_geom))
gives the longest line segment that can be drawn within the cluster of street address points. Works for non-curved streets. I'm still looking for a more intelligent way to thin out a polygon to a (multi)line.
Jan
On 02/21/2012 05:27 PM, Fawcett, David (MPCA) wrote:
If you are storing the data in PostGIS, you could possibly take advantage of ST_Azimuth(). http://www.postgis.org/docs/ST_Azimuth.html
It takes two point objects as the args, but you could potentially use the start and end points of your linestring.
David.
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jan Hartmann
Sent: Tuesday, February 21, 2012 10:23 AM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Aligning labels within a polygon
I'm inputting lots of street address points in PostGIS, and try to generate labels for the streets. The convex hull of the points of a street approximate the course of the street, and I would like to position the streetname in the middle of the convex hull polygon, aligned to its dominant angle (the polygons are generally quite narrow). Is there a way of doing this with MapServer? Perhaps by thinning out the polygon to a line, for then I can use "angle follow".
Jan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120221/40d5b32d/attachment.html
