[mapserver-users] Re: mssql2008 plugin not working / failed to load
dynamic library
juliap
japr94 at hotmail.com
Fri Feb 24 12:41:24 PST 2012
Thanks for the suggestion,
I was able to create a spatial index for the database using ogrinfo. I even
exported information from sql server to a shapefile using the ogr2ogr
utility.
However; I want to be able to get data directly from a query in the mapfile,
instead of having to create a shapefile. Right now this doesn't work when I
use CONNECTIONTYPE OGR, and the same string that I used to connect for the
previous examples.
Also, I tried to use the mssql2008 plugin, and I used dependency walker and
it seems that most of the required libraries cannot be found ...
Do you have any idea of what the problem could be?
View this message in context: http://osgeo-org.1560.n6.nabble.com/mssql2008-plugin-not-working-failed-to-load-dynamic-library-tp4492672p4504015.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
