[mapserver-users] WMS request not enabled
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Tue Feb 28 03:32:35 PST 2012
There is nothing wrong in your mapfile, only that you do not have any layers in it. I could repeat the behaviour by removing all the layers from my working mapfiles.
The error message in misleading.  I do not know what message there should be if there are no layers in the service but it is otherwise OK. However, something tells me that this might have corrected in a trunk already.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Luís de Sousa
> Lähetetty: 28. helmikuuta 2012 13:08
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] WMS request not enabled
> Dear all,
> Below goes a map file generated by PyWPS. This file is returning the
> following error on a GetCapabilities request:
> msWMSGetCapabilities(): WMS server error. WMS request not enabled.
> Check wms/ows_enable_request settings.
> There is a good deal of information on this list about this error,
> because when MapServer 6.0 was introduced many people didn't have the
> ows_enable_request parameter set. But PyWPS is correctly setting this
> parameter, so there's no apparent reason for this error to come up.
> What else can be causing this? Anything I can do to provide
> more information?
> Thank you and regards,
> Luís
> MAP
>   CONFIG "MS_ERRORFILE" "stderr"
>   DEBUG 5
>   EXTENT -180 -90 180 90
>   IMAGETYPE "png"
>   NAME "buffer-5989-tmpodARQz"
>   SIZE -1 -1
>   STATUS ON
>   UNITS METERS
>   OUTPUTFORMAT
>     NAME "png"
>     MIMETYPE "image/png"
>     DRIVER "AGG/PNG"
>     EXTENSION "png"
>     IMAGEMODE RGB
>     TRANSPARENT FALSE
>   END # OUTPUTFORMAT
>   PROJECTION
>     "init=epsg:4326"
>   END # PROJECTION
>   LEGEND
>     KEYSIZE 20 10
>     KEYSPACING 5 5
>     LABEL
>       SIZE MEDIUM
>       OFFSET 0 0
>       SHADOWSIZE 1 1
>       TYPE BITMAP
>     END # LABEL
>     STATUS OFF
>   END # LEGEND
>   QUERYMAP
>     SIZE -1 -1
>     STATUS OFF
>     STYLE HILITE
>   END # QUERYMAP
>   SCALEBAR
>     IMAGECOLOR 255 255 255
>     INTERVALS 4
>     LABEL
>       SIZE MEDIUM
>       OFFSET 0 0
>       SHADOWSIZE 1 1
>       TYPE BITMAP
>     END # LABEL
>     SIZE 200 3
>     STATUS OFF
>     UNITS MILES
>   END # SCALEBAR
>   WEB
>     METADATA
>       "wcs_label"	"Buffer process using OGR"
>       "wms_onlineresource"
> "http://localhost/cgi-bin/mapserv?map=/var/www/wps/wpsoutputs/
pywps-0d1bce24-5d36-11e1-99d2-0021cc5dbe3e.map"
>       "ows_country"	"eu"
>       "ows_keywordlist"	"GRASS,GIS,WPS"
>       "wms_abstract"	"See http://pywps.wald.intevation.org and
> http://www.opengeospatial.org/standards/wps"
>       "ows_city"	"City"
>       "ows_contactperson"	"Your Name"
>       "ows_contactposition"	"Your Position"
>       "ows_role"	"Your role"
>       "ows_enable_request"	"*"
>       "ows_contactorganization"	"Your Company Name"
>       "ows_accessconstraints"	"none"
>       "ows_title"	"PyWPS Server"
>       "ows_fees"	"None"
>       "wcs_abstract"	"See http://pywps.wald.intevation.org and
>       "ows_contactelectronicmailaddress"	"login at server.org"
>       "wfs_abstract"	"See http://pywps.wald.intevation.org and
>       "ows_address"	"Street"
>       "ows_postcode"	"000 00"
>     END # METADATA
>   END # WEB
> END # MAP
