[mapserver-users] WMS request not enabled
Luís de Sousa
luis.a.de.sousa at gmail.com
Tue Feb 28 03:07:35 PST 2012
Dear all,
Below goes a map file generated by PyWPS. This file is returning the
following error on a GetCapabilities request:
msWMSGetCapabilities(): WMS server error. WMS request not enabled.
Check wms/ows_enable_request settings.
There is a good deal of information on this list about this error,
because when MapServer 6.0 was introduced many people didn't have the
ows_enable_request parameter set. But PyWPS is correctly setting this
parameter, so there's no apparent reason for this error to come up.
What else can be causing this? Anything I can do to provide more information?
Thank you and regards,
Luís
MAP
CONFIG "MS_ERRORFILE" "stderr"
DEBUG 5
EXTENT -180 -90 180 90
IMAGETYPE "png"
NAME "buffer-5989-tmpodARQz"
SIZE -1 -1
STATUS ON
UNITS METERS
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT FALSE
END # OUTPUTFORMAT
PROJECTION
"init=epsg:4326"
END # PROJECTION
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
STATUS OFF
END # LEGEND
QUERYMAP
SIZE -1 -1
STATUS OFF
STYLE HILITE
END # QUERYMAP
SCALEBAR
IMAGECOLOR 255 255 255
INTERVALS 4
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
SIZE 200 3
STATUS OFF
UNITS MILES
END # SCALEBAR
WEB
METADATA
"wcs_label" "Buffer process using OGR"
"wms_onlineresource" "http://localhost/cgi-bin/mapserv?map=/var/www/wps/wpsoutputs/pywps-0d1bce24-5d36-11e1-99d2-0021cc5dbe3e.map"
"ows_country" "eu"
"ows_keywordlist" "GRASS,GIS,WPS"
"wms_abstract" "See http://pywps.wald.intevation.org and
http://www.opengeospatial.org/standards/wps"
"ows_city" "City"
"ows_contactperson" "Your Name"
"ows_contactposition" "Your Position"
"ows_role" "Your role"
"ows_enable_request" "*"
"ows_contactorganization" "Your Company Name"
"ows_accessconstraints" "none"
"ows_title" "PyWPS Server"
"ows_fees" "None"
"wcs_abstract" "See http://pywps.wald.intevation.org and
"ows_contactelectronicmailaddress" "login at server.org"
"wfs_abstract" "See http://pywps.wald.intevation.org and
"ows_address" "Street"
"ows_postcode" "000 00"
END # METADATA
END # WEB
END # MAP
