[mapserver-users] OGR and MSSQL non-specific error
Anzel, Phil - NRCS, Fort Collins, CO
Phil.Anzel at ftc.usda.gov
Wed Feb 29 09:30:45 PST 2012
Hi, Tamas,
Your reference to a geometry_metadata table is puzzling; we do not have that in our Sql Server 2008 databases except under one condition: those databases that were modified by addition of ESRI’s “SDE” product. We find that in these databases, the ownership of the geometry_metadata table is “sde”, which is quite telling.
Thanks for looking into this.
- Phil
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Wednesday, February 29, 2012 1:41 AM
To: Anzel, Phil - NRCS, Fort Collins, CO
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] OGR and MSSQL non-specific error
2012/2/28 Anzel, Phil - NRCS, Fort Collins, CO <Phil.Anzel at ftc.usda.gov<mailto:Phil.Anzel at ftc.usda.gov>>
Hi, Tamas,
I believe there is at least one bug in the OGR code: the SRID is not properly retrieved from the underlying Sql Server 2008 database or its value is ignored, and therefore zero records are returned.
Probably the geometry_columns metadata table contains incorrect srid for the NAV_STATE entry.
I also note that all columns are returned. That is unfortunate, as that could potentially represent quite a bit of network traffic,
This is a subject of improvement in the mapserver ogr driver. OGR is now capable to limit the fields by using OGR_L_SetIgnoredFields, but it hasn't been utilized yet. We should also modify the OGR mssql driver to rely on OGRFieldDefn::IsIgnored just like for the sqlite driver. Added 2 tickets to implement this addition:
http://trac.osgeo.org/mapserver/ticket/4217
http://trac.osgeo.org/gdal/ticket/4534
Best regards,
Tamas
This electronic message contains information generated by the USDA solely for the intended recipients. Any unauthorized interception of this message or the use or disclosure of the information it contains may violate the law and subject the violator to civil or criminal penalties. If you believe you have received this message in error, please notify the sender and delete the email immediately.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120229/eeeda0c1/attachment.html
