[mapserver-users] mapserv CGI - msPostGISLayerWhichShapes(): Item
query error.
Paul Deschamps
pdescham49 at gmail.com
Wed Feb 29 12:13:28 PST 2012
Hi List,
This looks familiar to me but it's eluding my brain right now as to why.
Mapserver / Postgis is generating an invalid SQL when trying to do an
itemquery a layer.
Here's the error from mapserv cgi
msPostGISLayerWhichShapes(): Query error. Error (ERROR: argument of AND
must be type boolean, not type integer LINE 1:
...29.8659509))',find_srid('',
'parcel','the_geom')) and (50105) ^ ) executing query: select
"id","transid","qpid","gis_acres","lastmodified",encode(ST_AsBinary(ST_Force_2D("the_geom"),'NDR'),'hex')
as geom,"id" from (select * from parcel) as foo where the_geom &&
GeomFromText('POLYGON((382577.69492276 1555529.8659509,382577.69492276
1851596.8951139,832467.25879056 1851596.8951139,832467.25879056
1555529.8659509))',find_srid('','parcel','the_geom')) and (50105)
Notice the end of the sql it is missing (qpid = 50105) qpid being set as
qitem is that not supposed to be there :)
Any assistance would be greatly appreciated :)
Paul
Here's the layer and versions ----
CGI params of interest:
&mode=itemquery&qitem=qpid&qstring=50105&qformat=parcel_as_html&qlayer=qparcel
Here's the layer:
LAYER
NAME 'qparcel'
INCLUDE 'projection.inc'
INCLUDE 'dbconnection.inc'
DATA 'the_geom from (select * from parcel) as foo using unique id'
TYPE POLYGON
STATUS OFF
METADATA
qstring_validation_pattern '.' # should set this to a regex specific
for this county
END
CLASS
NAME 'Selected Parcel'
OUTLINECOLOR 255 0 0
SYMBOL "circle"
SIZE 3
LABEL
COLOR 0 0 0
SIZE SMALL
MINDISTANCE 100
END
END
TEMPLATE 'void'
END
Postgis ver:
"POSTGIS="1.5.3" GEOS="3.3.1-CAPI-1.7.1" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.6" USE_STATS"
MapServer ver:
MapServer version 6.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120229/43c48621/attachment-0001.html
