[mapserver-users] .NET SWIG Mapscript - Bug or Doc issue
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Jan 10 10:37:59 EST 2012
Looking at mapserver.h the opacity attribute of a styleObj is exposed via SWIG. So it should
be mutable, so there's a documentation problem. You can read the mapfile, change the value
and save the mapfile as a quick test.
Can you try another language?
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of Stephen Woodbridge [woodbri at swoodbridge.com]
Sent: Friday, January 06, 2012 6:43 PM
To: mapserver-users
Subject: [mapserver-users] .NET SWIG Mapscript - Bug or Doc issue
Hi all,
The mapfile STYLE block[1] has OPACITY [integer|attribute] but I do not
see this attribute listed in the SWIG mapscript [2] styleObj Attributes
list.
And I have a report that when trying to use this via .NET mapscript that
it does not seem to work.
layerObj opacity seems to work just fine.
So, is this:
a. a code bug or oversight in the SWIG wrappers
b. something specific to .NET code
c. a documentation bug
d. something else all together
I'm happy to create appropriate bugs as needed.
[1] http://mapserver.org/mapfile/style.html
[2] http://mapserver.org/mapscript/mapscript.html#styleobj
Thanks,
-Steve W
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
