[mapserver-users] layerObj.setFilter parser error
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Wed Jan 11 18:18:44 EST 2012
I don't know of a simple work around. MapScript and the mapfile parser use the same expression tokenizing routine. What happens if you try single quotes? That is:
layerObj.setFilter ( '(point.id = 1)' )
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Radim Blazek
Sent: Tuesday, January 10, 2012 12:05 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] layerObj.setFilter parser error
If I use layerObj.setFilter ( "(point.id = 1)" ), mapObj.OWSDispatch
gives an error:
"msTokenizeExpression(): Expression parser error. Parsing time value failed.
msParseTime(): Regular expression error. Unrecognized date or
time format ()."
It works correctly with layerObj.setFilter ( "( id = 1)" ) or
layerObj.setFilter ( "point.id = 1" ).
FILTER "( point.id = 1 )" in mapfile also works.
This is of course only a simple example, I need both fully qualified
column name and parenthesis.
It seems to be a bug. Do you know any simple trick, how to get it
working for a presentation tomorrow morning?
Version 6.0.1.
Thanks
Radim
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
