[mapserver-users] Re: Clustering and tile clipping
Wim Vanbelle
wimvanbelle at gmail.com
Mon Jan 16 03:10:49 EST 2012
Does anyone have any working examples of how they implemented clustering
without the tile clipping?
Thanks.
On 11 January 2012 10:00, Wim Vanbelle <wimvanbelle at gmail.com> wrote:
> Hi,
> I'm very happy that mapserver is now capable of server side clustering.
> However I wonder if it's possible to completely get rid of the tile
> clipping.
> Currently I've clustered a point layer with 44k points:
> CLUSTER
> MAXDISTANCE 100
> REGION "ellipse"
> END
> It is displayed with a simple image:
> STYLE
> SYMBOL "small_shaded.png"
> SIZE 21
> OUTLINECOLOR 0 0 0
> END
> However, when viewing this on google maps, the images are often clipped at
> the tile edges.
> I figured that I could solve this with mapcache:
> <tileset name="ld">
> <source>ld</source>
> <cache>disk</cache>
> <grid>g2</grid>
> <format>PNG</format>
> <metatile>2 2</metatile>
> <metabuffer>30</metabuffer>
> <expires>3600</expires>
> <auto_expire>2592000</auto_expire>
> </tileset>
> i've tried higher values for metatile and it helps a bit, but the problem
> simply shifts location. Also with higher values (eg 5 5 metatile) mapserver
> doesn't return the tiles on time for mapcache and I get gaps in my results.
> Would preseeding the data help with the timeouts? Any other solutions that
> I may try? The metadata parameter for tile_edge buffer only works with
> labels as far as i know.
> Thanks in advance, this issue has been troubling me for some time now :).
> Best regards,
> Wim
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120116/810e2bc3/attachment.html
