[mapserver-users] Re: Clustering and tile clipping
Tamas Szekeres
szekerest at gmail.com
Mon Jan 16 04:55:57 EST 2012
Hi Wim,
Did you try the BUFFER setting to increase the search area during the
cluster creation?
For more information see: http://mapserver.org/mapfile/cluster.html
Best regards,
Tamas
2012/1/16 Wim Vanbelle <wimvanbelle at gmail.com>
> Does anyone have any working examples of how they implemented clustering
> without the tile clipping?
> Thanks.
> On 11 January 2012 10:00, Wim Vanbelle <wimvanbelle at gmail.com> wrote:
>> Hi,
>> I'm very happy that mapserver is now capable of server side clustering.
>> However I wonder if it's possible to completely get rid of the tile
>> clipping.
>> Currently I've clustered a point layer with 44k points:
>> CLUSTER
>> MAXDISTANCE 100
>> REGION "ellipse"
>> END
>> It is displayed with a simple image:
>> STYLE
>> SYMBOL "small_shaded.png"
>> SIZE 21
>> OUTLINECOLOR 0 0 0
>> END
>> However, when viewing this on google maps, the images are often clipped
>> at the tile edges.
>> I figured that I could solve this with mapcache:
>> <tileset name="ld">
>> <source>ld</source>
>> <cache>disk</cache>
>> <grid>g2</grid>
>> <format>PNG</format>
>> <metatile>2 2</metatile>
>> <metabuffer>30</metabuffer>
>> <expires>3600</expires>
>> <auto_expire>2592000</auto_expire>
>> </tileset>
>> i've tried higher values for metatile and it helps a bit, but the problem
>> simply shifts location. Also with higher values (eg 5 5 metatile) mapserver
>> doesn't return the tiles on time for mapcache and I get gaps in my results.
>> Would preseeding the data help with the timeouts? Any other solutions
>> that I may try? The metadata parameter for tile_edge buffer only works with
>> labels as far as i know.
>> Thanks in advance, this issue has been troubling me for some time now :).
>> Best regards,
>> Wim
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120116/33b570f4/attachment.html
