[mapserver-users] Shapefiles not rendered
Juan Jesús Cremades Monserrat relicary at gmail.com
Mon Jan 16 03:45:47 EST 2012
Hi David,
Muy BBOX is defined into a JS with OpenLayers. When I create the
"OpenLayers.Map" object, the opcion values are:
 minExtent : new OpenLayers.Bounds(-1, -1, 1, 1),
maxResolution : 0.35,
maxZoomLevel : 10,
maxExtent : new OpenLayers.Bounds(-180, -90, 180, 90)
I tried change the Space Reference System or coomenting the TRANSPARENCY,
MINSCALE & MAXSCALE parameters, but The problem contues.
Too I was trying change LAYER METADATA vms_extend parameter with degree
values, but nothing.
I was tried this map file at the gvSIG DEsktop, and it works... But I don'
konw what,s the problem with the server.
Cheers
2012/1/13 Fawcett, David (MPCA) <David.Fawcett at state.mn.us>
>  Juan, ****
> The projection block at the map level specifies 4326 as the spatial
> reference system, but the units of your extent look like they are in
> meters, not decimal degrees.  This may be involved in the issue, or maybe
> not, but it would screw up a regular MapServer CGI request if you don’t
> specify a bbox.  ****
> The use of a ‘.’ Character in a layer name may be valid in MapServer and
> the OGC WMS spec, but it looks funky to me.  Again, probably not the
> problem.****
> I would simplify your map file by commenting out the MINSCALE, MAXSCALE,
> and TRANSPARENCY lines.  I am guessing that one of these is causing your
> problem.****
> David.****
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Juan Jesús
> Cremades Monserrat
> *Sent:* Friday, January 13, 2012 5:50 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Shapefiles not rendered****
> Hi,****
> I want execute the getMap method with an URL like this:****
> http://localhost:9000/cgi-bin/mapserv.exe?LAYERS=COMACOM.SHP&FORMAT=image/png&TRANSPARENT=true&MAP=/ms4w/apps/demo-cv/demoCV.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=EPSG:4326&BBOX=-180,-90,180,90&WIDTH=551&HEIGHT=356
> But the result is always a white page. Where the error may be? My
> MapServer is the MS4W. Thanks****
> My MapFile is this:****
> MAP****
>    NAME map_generated_by_gvsig****
>    EXTENT 626679.4375 4191039.75 797868.9375 4519396.0****
>    SYMBOLSET "demoCV.sym"****
>    FONTSET "fonts.txt"****
>    LEGEND****
>       IMAGECOLOR -1 -1 -1****
>       LABEL****
>          FONT "vera"****
>          ANGLE FOLLOW****
>          COLOR 0 0 0****
>          ENCODING "UTF-8"****
>          TYPE truetype****
>          SIZE 8****
>       END****
>       STATUS ON****
>       TRANSPARENT ON****
>    END****
>    SIZE 800 800****
>       OUTPUTFORMAT****
>         NAME PNG24****
>         DRIVER AGG/PNG****
>         IMAGEMODE RGB****
>    END****
>    WEB****
>       METADATA****
>          "wms_encoding" "UTF-8"****
>          "wms_title" "Mapserver WMS"****
>          "wms_abstract" ""****
>          "wms_srs" " EPSG:4326"****
>          "wms_onlineresource" "
> http://localhost:9000/cgi-bin/mapserv.exe?map=E%3A%5Cms4w%5Capps%5Cdemo-cv%5CdemoCV.map
>          "ows_enable_request" "*"****
>          "wms_feature_info_mime_type" "text/html"****
>       END****
>    END****
>    PROJECTION****
>       "init=epsg:4326"****
>    END****
>    LAYER****
>       NAME "COMACOM.SHP"****
>       STATUS ON****
>       DUMP true****
>       TEMPLATE "templates/provincias.html"****
>       TYPE POLYGON****
>       DATA "E:\COMACOM.SHP"****
>       MAXSCALE -1.0****
>       MINSCALE -1.0****
>       TRANSPARENCY 100****
>       SIZEUNITS pixels****
>       PROJECTION****
>       END****
>       CLASS****
>          STYLE ****
>             COLOR 104 108 2****
>             OUTLINECOLOR 72 75 1****
>             WIDTH 1****
>          END****
>          NAME "default"****
>       END****
>       METADATA****
>          "wms_title" "COMACOM.SHP"****
>          "wms_abstract" "generated by gvSIG"****
>          "wms_extent" "626679.4375 4191039.75 797868.9375 4519379.0"****
>          "gml_include_items" "all"****
>       END****
>    END # Layer****
> END # Map File****
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120116/8859612f/attachment.html
