[mapserver-users] Shapefiles not rendered
Juan Jesús Cremades Monserrat
relicary at gmail.com
Thu Jan 19 11:19:38 EST 2012
Hi David,
Thank you about your clues I've resolveed the problem. You have reason, the
projection and the units weren't wrong.
El 16 de enero de 2012 09:45, Juan Jesús Cremades Monserrat <
relicary at gmail.com> escribió:
> Hi David,
> Muy BBOX is defined into a JS with OpenLayers. When I create the
> "OpenLayers.Map" object, the opcion values are:
> minExtent : new OpenLayers.Bounds(-1, -1, 1, 1),
> maxResolution : 0.35,
> maxZoomLevel : 10,
> maxExtent : new OpenLayers.Bounds(-180, -90, 180, 90)
> I tried change the Space Reference System or coomenting the TRANSPARENCY,
> MINSCALE & MAXSCALE parameters, but The problem contues.
> Too I was trying change LAYER METADATA vms_extend parameter with degree
> values, but nothing.
> I was tried this map file at the gvSIG DEsktop, and it works... But I don'
> konw what,s the problem with the server.
> Cheers
> 2012/1/13 Fawcett, David (MPCA) <David.Fawcett at state.mn.us>
> Juan, ****
>> The projection block at the map level specifies 4326 as the spatial
>> reference system, but the units of your extent look like they are in
>> meters, not decimal degrees. This may be involved in the issue, or maybe
>> not, but it would screw up a regular MapServer CGI request if you don’t
>> specify a bbox. ****
>> The use of a ‘.’ Character in a layer name may be valid in MapServer and
>> the OGC WMS spec, but it looks funky to me. Again, probably not the
>> problem.****
>> I would simplify your map file by commenting out the MINSCALE, MAXSCALE,
>> and TRANSPARENCY lines. I am guessing that one of these is causing your
>> problem.****
>> David.****
>> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
>> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Juan Jesús
>> Cremades Monserrat
>> *Sent:* Friday, January 13, 2012 5:50 AM
>> *To:* mapserver-users at lists.osgeo.org
>> *Subject:* [mapserver-users] Shapefiles not rendered****
>> Hi,****
>> I want execute the getMap method with an URL like this:****
>> http://localhost:9000/cgi-bin/mapserv.exe?LAYERS=COMACOM.SHP&FORMAT=image/png&TRANSPARENT=true&MAP=/ms4w/apps/demo-cv/demoCV.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&SRS=EPSG:4326&BBOX=-180,-90,180,90&WIDTH=551&HEIGHT=356
>> But the result is always a white page. Where the error may be? My
>> MapServer is the MS4W. Thanks****
>> My MapFile is this:****
>> MAP****
>> NAME map_generated_by_gvsig****
>> EXTENT 626679.4375 4191039.75 797868.9375 4519396.0****
>> SYMBOLSET "demoCV.sym"****
>> FONTSET "fonts.txt"****
>> LEGEND****
>> IMAGECOLOR -1 -1 -1****
>> LABEL****
>> FONT "vera"****
>> ANGLE FOLLOW****
>> COLOR 0 0 0****
>> ENCODING "UTF-8"****
>> TYPE truetype****
>> SIZE 8****
>> END****
>> STATUS ON****
>> TRANSPARENT ON****
>> END****
>> SIZE 800 800****
>> OUTPUTFORMAT****
>> NAME PNG24****
>> DRIVER AGG/PNG****
>> IMAGEMODE RGB****
>> END****
>> WEB****
>> METADATA****
>> "wms_encoding" "UTF-8"****
>> "wms_title" "Mapserver WMS"****
>> "wms_abstract" ""****
>> "wms_srs" " EPSG:4326"****
>> "wms_onlineresource" "
>> http://localhost:9000/cgi-bin/mapserv.exe?map=E%3A%5Cms4w%5Capps%5Cdemo-cv%5CdemoCV.map
>> "ows_enable_request" "*"****
>> "wms_feature_info_mime_type" "text/html"****
>> END****
>> END****
>> PROJECTION****
>> "init=epsg:4326"****
>> END****
>> LAYER****
>> NAME "COMACOM.SHP"****
>> STATUS ON****
>> DUMP true****
>> TEMPLATE "templates/provincias.html"****
>> TYPE POLYGON****
>> DATA "E:\COMACOM.SHP"****
>> MAXSCALE -1.0****
>> MINSCALE -1.0****
>> TRANSPARENCY 100****
>> SIZEUNITS pixels****
>> PROJECTION****
>> END****
>> CLASS****
>> STYLE ****
>> COLOR 104 108 2****
>> OUTLINECOLOR 72 75 1****
>> WIDTH 1****
>> END****
>> NAME "default"****
>> END****
>> METADATA****
>> "wms_title" "COMACOM.SHP"****
>> "wms_abstract" "generated by gvSIG"****
>> "wms_extent" "626679.4375 4191039.75 797868.9375 4519379.0"****
>> "gml_include_items" "all"****
>> END****
>> END # Layer****
>> END # Map File****
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120119/eb3714f5/attachment-0001.html
