[mapserver-users] Re: Shape File not appearing
knasia
knasia at poczta.fm
Mon Jan 16 03:54:10 EST 2012
I still have the same problem, but now I have mapfile working (I have it
generated by QGIS).
It looks like:
# Map file created from QGIS project file C:/Documents and
Settings/Katarzyna/Pulpit/ver 17/projekt/graf.qgs
# Edit this file to customize for your map interface
# (Created with PyQgis MapServer Export plugin)
MAP
NAME "ruch"
# Map image size
SIZE 256 256
UNITS dd
EXTENT 19.735012 49.941251 20.114223 50.170585
FONTSET './fonts/fonts.list'
SYMBOLSET './symbols/symbols.sym'
SHAPEPATH "pathxxx/shapes/"
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
IMAGEMODE RGBA
EXTENSION 'png'
END
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH '/tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/tmp/'
TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
END
LAYER
NAME 'krakowGraf'
TYPE LINE
DUMP true
TEMPLATE fooOnlyForWMSGetFeatureInfo
DATA 'krakowGraf.shp'
METADATA
'ows_title' 'krakowGraf'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
CLASS
NAME 'krakowGraf'
STYLE
WIDTH 0.91
COLOR 191 45 220
END
END
END
END
When i try to access it from browser as
http://mypath/cgi-bin/mapserv?map=/home/mapy/Mapy-mapserver/baseMaps.map&layers=all&mode=map&bogus=1326701290954
it works- my layer is drawn.
Now I want to put this layer on the google maps base.
I have tried:
var urlTemplate = '/cgi-bin/mapserv?';
urlTemplate += 'map=/home/mapy/Mapy-mapserver/baseMaps.map&';
urlTemplate += 'layers=';
urlTemplate += 'all';
urlTemplate += '&';
urlTemplate += 'mode=map&';
baseMapsLayer1a = new GTileLayer(null,0,13,{
tileUrlTemplate:urlTemplate,
isPng:true,
opacity:1.0 });
baseMapsLayer1b=new GTileLayerOverlay(baseMapsLayer1a);
map.addOverlay(pointsLayer1b);
but none of data appeared.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Shape-File-not-appearing-tp6896942p7191824.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
