[mapserver-users] Postgis layer and SLD
Carman, Darren darren.carman at infoterra-global.com
Mon Jan 16 12:10:15 EST 2012
I am using mapserver 5.6.7 trying to get SLDs to work for a postgis
layer.
I can get this to work when adding the SLD parameter onto the url but
cannot get it to work using the wms_sld_url parameter in the mapfile.
Should it be possible to have this working from the mapfile? I have also
tried the wms_style and wms_style_<stylename>_sld metadata parameters
with no luck as well.
The reason I ask is that we have many layers stored in
postgresql/postgis with different SLDs for each. I am hoping I have done
something wrong in the mapfile (or missing something vital) so that I
can set up the layers to use individual SLDs - the alternative is for me
to combine the SLDs into 1 xml file, which is work I would like to avoid
if the mapfile solution is possible.
Thanks for any help in advance
My layer config:
LAYER
  NAME layer1
  CONNECTIONTYPE postgis
  CONNECTION "user=<user> password=<password> dbname=<database>
host=<host>"
  DATA "geometry from <table> using unique geometry using SRID=27700"
  PROJECTION
    "init=epsg:27700"
  END
  DUMP true
  METADATA
    "wms_title" "Layer 1"
    "wms_srs"   "EPSG:27700"
   "wms_server_version" "1.3.0"
    "wms_name" "sldname"
    "wms_boundingbox" "EPSG:27700 0 0 700000 1300000"
    "wms_latlonboundingbox" "-7.556 49.776 2.934 60.810"
    "wfs_extent" "0 0 700000 1300000"
    "wms_sld_url" "http://<my server>/SLDs/MySLD.sld"
  END
  TYPE POINT
  STATUS ON
  CLASS
    NAME "POI"
    COLOR 0 0 255
    symbol 'circle'
    size 10
  END
END
Regards,
Darren
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120116/92f6c105/attachment.html
