[mapserver-users] Postgis layer and SLD
Francesco D'Alesio
francesco.dalesio at r3-gis.com
Tue Jan 17 02:37:28 EST 2012
Hi Darren,
I think wms_style and wms_style_<stylename>_sld works only when
cascading external WMS (CONNECTIONTYPE WMS).
You can use SLDs with postgis layers using mapscript applySLD()
Francesco
Il 16/01/2012 18:10, Carman, Darren ha scritto:
> Hi,
> I am using mapserver 5.6.7 trying to get SLDs to work for a postgis layer.
> I can get this to work when adding the SLD parameter onto the url but
> cannot get it to work using the wms_sld_url parameter in the mapfile.
> Should it be possible to have this working from the mapfile? I have
> also tried the wms_style and wms_style_<stylename>_sld metadata
> parameters with no luck as well.
> The reason I ask is that we have many layers stored in
> postgresql/postgis with different SLDs for each. I am hoping I have
> done something wrong in the mapfile (or missing something vital) so
> that I can set up the layers to use individual SLDs -- the alternative
> is for me to combine the SLDs into 1 xml file, which is work I would
> like to avoid if the mapfile solution is possible.
> Thanks for any help in advance
> My layer config:
> LAYER
> NAME layer1
> CONNECTIONTYPE postgis
> CONNECTION "user=<user> password=<password> dbname=<database>
> host=<host>"
> DATA "geometry from <table> using unique geometry using SRID=27700"
> PROJECTION
> "init=epsg:27700"
> END
> DUMP true
> METADATA
> "wms_title" "Layer 1"
> "wms_srs" "EPSG:27700"
> "wms_server_version" "1.3.0"
> "wms_name" "sldname"
> "wms_boundingbox" "EPSG:27700 0 0 700000 1300000"
> "wms_latlonboundingbox" "-7.556 49.776 2.934 60.810"
> "wfs_extent" "0 0 700000 1300000"
> "wms_sld_url" "http://<my server>/SLDs/MySLD.sld"
> END
> TYPE POINT
> STATUS ON
> CLASS
> NAME "POI"
> COLOR 0 0 255
> symbol 'circle'
> size 10
> END
> END
> Regards,
> Darren
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120117/de462302/attachment.html
