[mapserver-users] Mapserver + regex license
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 18 11:09:14 EST 2012
On 12-01-18 07:54 AM, Lime, Steve D (DNR) wrote:
> I'm hoping someone with experience in this area can chime in. It's a convoluted
> subject for sure. MapServer doesn't contain code from any regex library, it uses
> an API that a few regex libs support so you can actually compile against others.
> Steve
Steve / Josef,
First, as Steve suggests the issue only arises if you build with
the GPL'ed regex 0.12. Second, requirements for redistribution of
source in the GPLv2 only apply if you distribute MapServer binaries
to clients or users (as opposed to putting up a service on your
own servers that outsiders use). Third, the redistribution of
source requirements is normally considered to only apply to code
linked into the executable. While this is a bit of a grey area,
it would not normally apply to the PHP/Python/Perl scripts using
the mapscript api.
So you are likely in the clear.
Best regards,
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Josef Bicik
> Sent: Monday, January 16, 2012 7:47 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Mapserver + regex license
> Hi All,
> I have a question about Mapserver licensing. From the documentation
> and source code I understand that Mapserver uses the regex 0.12
> library, which is released under the GNU GPL v2 license. Can Mapserver
> actually be released under an MIT-style license when it contains
> portions of code released under GPL? I am not extending mapserver on
> its own, however, am considering using mapscript in a commercial
> application. I wonder if I would have to release my application using
> mapscript under GPL v2 license. Can anybody please explain me this
> licensing issue?
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush | Geospatial Software Developer
