[mapserver-users] 16 bit PNG or 16 bit jpeg output
Ragi Burhum
ragi at burhum.com
Thu Jan 19 12:02:35 EST 2012
Hi Jukka,
I assume you mean WCS 2.0 and that you are referring to the MEDIATYPE
directive. The documentation at
http://mapserver.org/ogc/wcs_server.html#test-your-wcs-1-0-server said that
only "multipart/mixed" was allowed. Am I mistaken?
> Date: Thu, 19 Jan 2012 08:13:54 +0000
> From: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Subject: Re: [mapserver-users] 16 bit PNG or 16 bit jpeg output
> To: "'mapserver-users at lists.osgeo.org'"
> <mapserver-users at lists.osgeo.org>
> Message-ID:
> <84446DEF76453C439E9E97E438E13A63063812 at suutari.haapa.mmm.fi>
> Content-Type: text/plain; charset="us-ascii"
> Hi,
> Could it be possible for you to use WCS 1.0.0 for avoiding the multipart
> thing?
> -Jukka Rahkonen-
> ________________________________
> Ragi Burhum wrote:
> Hello,
> I am trying to output a single band 16bit png (or jpeg) output from a
> Mapserver WCS service.
> I have tried the following output formats:
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "GDAL/JPEG"
> MIMETYPE "image/jpeg"
> IMAGEMODE INT16
> EXTENSION "jpg"
> FORMATOPTION "QUALITY=85"
> END
> OUTPUTFORMAT
> NAME GDALPNG
> DRIVER "GDAL/PNG"
> MIMETYPE "image/png"
> IMAGEMODE INT16
> EXTENSION "png"
> FORMATOPTION "FILENAME=result.png"
> END
> When I try different IMAGEMODEs, I get the correct results, but for some
> reason, INT16 does not work. I looked through the mailing list and I
> noticed that this question has been asked before:
> http://osgeo-org.1803224.n2.nabble.com/16-Bit-PNG-Output-td6249725.html
> http://osgeo-org.1803224.n2.nabble.com/Using-a-16-bit-per-band-PNG-image-td2490088.html
> I tried looking for a ticket in Trac, but I had no luck. Am I doing
> something wrong? Perhaps I could accomplish this somehow with a custom gdal
> driver?
> Also, a side question, if I wanted to make sure the replies from my WCS
> getcoverage calls were not multipart (I am just interested in the binary
> output), is there some mapserver-specific setting I can use to just get
> that image as a reply instead of the accompanying xml files?
> Thanks!
> - Ragi
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120119/604b09e6/attachment.html
