[mapserver-users] 16 bit PNG or 16 bit jpeg output
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Jan 19 12:16:00 EST 2012
No way, I mean the WCS version 1.0 as described in the very same document http://www.mapserver.org/ogc/wcs_server.html
-Jukka Rahkonen-
Lähettäjä: Ragi Burhum [ragi at burhum.com]
Lähetetty: 19. tammikuuta 2012 19:02
Vastaanottaja: mapserver-users at lists.osgeo.org; Rahkonen Jukka
Aihe: Re: [mapserver-users] 16 bit PNG or 16 bit jpeg output
Hi Jukka,
I assume you mean WCS 2.0 and that you are referring to the MEDIATYPE directive. The documentation at http://mapserver.org/ogc/wcs_server.html#test-your-wcs-1-0-server said that only "multipart/mixed" was allowed. Am I mistaken?
Date: Thu, 19 Jan 2012 08:13:54 +0000
From: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi<mailto:Jukka.Rahkonen at mmmtike.fi>>
Subject: Re: [mapserver-users] 16 bit PNG or 16 bit jpeg output
To: "'mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>'"
<mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
Message-ID:
<84446DEF76453C439E9E97E438E13A63063812 at suutari.haapa.mmm.fi<mailto:84446DEF76453C439E9E97E438E13A63063812 at suutari.haapa.mmm.fi>>
Content-Type: text/plain; charset="us-ascii"
Could it be possible for you to use WCS 1.0.0 for avoiding the multipart thing?
-Jukka Rahkonen-
Ragi Burhum wrote:
Hello,
I am trying to output a single band 16bit png (or jpeg) output from a Mapserver WCS service.
I have tried the following output formats:
OUTPUTFORMAT
NAME jpeg
DRIVER "GDAL/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE INT16
EXTENSION "jpg"
FORMATOPTION "QUALITY=85"
END
OUTPUTFORMAT
NAME GDALPNG
DRIVER "GDAL/PNG"
MIMETYPE "image/png"
IMAGEMODE INT16
EXTENSION "png"
FORMATOPTION "FILENAME=result.png"
END
When I try different IMAGEMODEs, I get the correct results, but for some reason, INT16 does not work. I looked through the mailing list and I noticed that this question has been asked before:
http://osgeo-org.1803224.n2.nabble.com/16-Bit-PNG-Output-td6249725.html
http://osgeo-org.1803224.n2.nabble.com/Using-a-16-bit-per-band-PNG-image-td2490088.html
I tried looking for a ticket in Trac, but I had no luck. Am I doing something wrong? Perhaps I could accomplish this somehow with a custom gdal driver?
Also, a side question, if I wanted to make sure the replies from my WCS getcoverage calls were not multipart (I am just interested in the binary output), is there some mapserver-specific setting I can use to just get that image as a reply instead of the accompanying xml files?
Thanks!
- Ragi
