[mapserver-users] Re: Trouble with South pole projection issues
Fri Jan 20 15:40:05 EST 2012
On Fri, Jan 20, 2012 at 11:51 AM, Fuchs Juan Carlos <
jfuch at indec.mecon.gov.ar> wrote:
> Hi Mr Frank Warmerdam****
> I sent out this post, but no one answer, so I´m here, bothering you again.
> Any adwise would gratefull received!****
> Happy New Year!****
> Juan Carlos Fuchs, from ****Argentina****.
> This is the *.prj from the shp i have, and need to bring along with the
> other one.****
> PROJCS["lambert",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["False_Easting",10000000.0],PARAMETER["False_Northing",6391246.5],PARAMETER["Central_Meridian",-60.0],PARAMETER["Latitude_Of_Origin",-40.0],UNIT["Meter",1.0]]
> that is my first try so far,: from my *.map file layer (Projection)****
>             PROJECTION****
>                         "proj=laea"****
>                         "ellps=WGS84"****
>                         "lat_1=40"****
>                         "lon_0=-60"****
>                         "south"****
>             END****
> As you can see it goes LL EPSG:4326 in geographics (????) is there some
> doc I can read about the "towgs84" Parameters, my guess is that they have
> not to be 0,0,0,0,0,0,0....****
Juan,
I do not believe the problem is related to the +towgs84 datum shifting.  I
believe the problem is that your LAEA projection definition for MapServer
lacks the false easting and northing values.  Try something like:
PROJECTION
   "+proj=laea +ellps=WGS84 +lat_1=40 +lon_0=-60 +south +x_0=10000000.0
+y_0=6391246.5"
END
The key change here being the addition of +x_0 and +y_0.  I am not familiar
with the
+south parameter for LAEA though it might be appropriate.
By the way, you can use the new gdalsrsinfo utility to translate coordinate
systems with GDAL.  eg.
warmerdam at gdal:~$ gdalsrsinfo
ESRI::'PROJCS["lambert",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["False_Easting",10000000.0],PARAMETER["False_Northing",6391246.5],PARAMETER["Central_Meridian",-60.0],PARAMETER["Latitude_Of_Origin",-40.0],UNIT["Meter",1.0]]'
PROJ.4 : '+proj=laea +lat_0=-40 +lon_0=-60 +x_0=10000000 +y_0=6391246.5
+datum=WGS84 +units=m +no_defs '
OGC WKT :
PROJCS["lambert",
        DATUM["WGS_1984",
            SPHEROID["WGS_84",6378137.0,298.257223563]],
    PARAMETER["longitude_of_center",-60.0],
    PARAMETER["latitude_of_center",-40.0],
    UNIT["Meter",1.0]]
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | Geospatial Software Developer
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120120/2164d103/attachment.html
