[mapserver-users] 16 bit PNG or 16 bit jpeg output
Ragi Burhum
ragi at burhum.com
Thu Jan 19 15:41:56 EST 2012
Hello Jukka and Stephan,
Thank you a lot for the pointer. Yes, version 1.0.0 definitely does the
trick and I will use that instead. I got a big confused with the
documentation and it was not too clear to me that was the behavior. Thank
you!
As far as my original question for 16bit png (or jpeg) output, is there
something that can be done about that?
The tiff output files I get are too big for such a small area and it makes
unusable for mobile devices.
Thanks again,
- Ragi
> Date: Thu, 19 Jan 2012 18:46:37 +0100
> From: Stephan Mei?l <stephan at meissl.name>
> Subject: Re: [mapserver-users] 16 bit PNG or 16 bit jpeg output
> To: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Cc: "mapserver-users at lists.osgeo.org"
> <mapserver-users at lists.osgeo.org>
> Message-ID: <1326995197.2995.49.camel at io>
> Content-Type: text/plain; charset="UTF-8"
> Hi,
> if you omit the mediatype parameter with version 2.0 you definitely get
> back only the binary output as requested in the format parameter. In WCS
> 1.1 afaik you always get back a multipart response and in WCS 1.0 always
> only the binary.
> cu
> Stephan
> On Thu, 2012-01-19 at 17:16 +0000, Rahkonen Jukka wrote:
> > Hi,
> > No way, I mean the WCS version 1.0 as described in the very same
> document http://www.mapserver.org/ogc/wcs_server.html
> > -Jukka Rahkonen-
> > ________________________________
> > LƤhettƤjƤ: Ragi Burhum [ragi at burhum.com]
> > LƤhetetty: 19. tammikuuta 2012 19:02
> > Vastaanottaja: mapserver-users at lists.osgeo.org; Rahkonen Jukka
> > Aihe: Re: [mapserver-users] 16 bit PNG or 16 bit jpeg output
> > Hi Jukka,
> > I assume you mean WCS 2.0 and that you are referring to the MEDIATYPE
> directive. The documentation at
> http://mapserver.org/ogc/wcs_server.html#test-your-wcs-1-0-server said
> that only "multipart/mixed" was allowed. Am I mistaken?
> > Date: Thu, 19 Jan 2012 08:13:54 +0000
> > From: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi<mailto:
> Jukka.Rahkonen at mmmtike.fi>>
> > To: "'mapserver-users at lists.osgeo.org<mailto:
> mapserver-users at lists.osgeo.org>'"
> > <mapserver-users at lists.osgeo.org<mailto:
> mapserver-users at lists.osgeo.org>>
> > Message-ID:
> > <84446DEF76453C439E9E97E438E13A63063812 at suutari.haapa.mmm.fi
> <mailto:84446DEF76453C439E9E97E438E13A63063812 at suutari.haapa.mmm.fi>>
> > Content-Type: text/plain; charset="us-ascii"
> > Hi,
> > Could it be possible for you to use WCS 1.0.0 for avoiding the multipart
> thing?
> > -Jukka Rahkonen-
> > Ragi Burhum wrote:
> > Hello,
> > I am trying to output a single band 16bit png (or jpeg) output from a
> Mapserver WCS service.
> > I have tried the following output formats:
> > OUTPUTFORMAT
> > NAME jpeg
> > DRIVER "GDAL/JPEG"
> > MIMETYPE "image/jpeg"
> > IMAGEMODE INT16
> > EXTENSION "jpg"
> > FORMATOPTION "QUALITY=85"
> > END
> > OUTPUTFORMAT
> > NAME GDALPNG
> > DRIVER "GDAL/PNG"
> > MIMETYPE "image/png"
> > IMAGEMODE INT16
> > EXTENSION "png"
> > FORMATOPTION "FILENAME=result.png"
> > END
> > When I try different IMAGEMODEs, I get the correct results, but for some
> reason, INT16 does not work. I looked through the mailing list and I
> noticed that this question has been asked before:
> > http://osgeo-org.1803224.n2.nabble.com/16-Bit-PNG-Output-td6249725.html
> http://osgeo-org.1803224.n2.nabble.com/Using-a-16-bit-per-band-PNG-image-td2490088.html
> > I tried looking for a ticket in Trac, but I had no luck. Am I doing
> something wrong? Perhaps I could accomplish this somehow with a custom gdal
> driver?
> > Also, a side question, if I wanted to make sure the replies from my WCS
> getcoverage calls were not multipart (I am just interested in the binary
> output), is there some mapserver-specific setting I can use to just get
> that image as a reply instead of the accompanying xml files?
> > Thanks!
> > - Ragi
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120119/04117de1/attachment.html
