[mapserver-users] shape->draw problem
Bistrais, Bob
Bob.Bistrais at maine.gov
Wed Jan 25 10:28:20 EST 2012
Hi Alan,
I worked with the nextShape() a little bit as follows:
for ($i=0; $i<=($oLayer_master->getNumResults() - 1); $i++) {
while($oShape = $oLayer_master->nextShape()){
$oResult = $oLayer_master->getResult($i);
$oLayer_master->open();
$oShape = $oLayer_master->getShape($oResult);
$oShape->draw($oMap,$oLayer_shape,$oImage);
$oLayer_master->close();
That appears to have fixed the error message I was getting, but it still
does not draw results (it should).
You brought up a good point regarding the query. Here is the query
language, at least what I could find (it's worth noting I did not write
the application, but am now responsible to maintain it):
$query = $_GET['qpub'];
$query = '("[PUBCODE]" = "'.$_GET['qpub'].'")';
$oLayer_master->queryByAttributes("PUBCODE", $query,
MS_MULTIPLE);
pubExtent2($oLayer_master, $oMap);
-----Original Message-----
From: Alan Boudreault [mailto:aboudreault at mapgears.com]
Sent: Sunday, January 22, 2012 5:41 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] shape->draw problem
Hi Bob,
I do not see any query in your code. Not sure why numresults return a
non-zero value. Check the example of the getShape() or nextShape()
functions in the documentation:
http://mapserver.org/mapscript/php/index.html#layerobj
Alan
On 12-01-20 03:55 PM, Bistrais, Bob wrote:
> I'm upgrading an application from Mapserver 5.6 to 6.0.1, PHP
MapScript.
> I'm having a problem with one section of code where it gives a
> shape->draw command. In MS 5.6, the Shape was derived from a
getFeature
> method, but in MS 6 this had to be changed to a getShape. The next
> command is to draw the shape. This returns the following error:
> Fatal error: Uncaught exception 'MapScriptException' in
> C:\ms4w_303\apps\mgs\htdocs\drawMap_detail_spatial.php:101 Stack
trace:
> #0 C:\ms4w_303\apps\mgs\htdocs\drawMap_detail_spatial.php(101):
> shapeObj->draw(Object(mapObj), Object(layerObj), Object(imageObj)) #1
> {main} thrown in
> on line 101
> Here is the code leading up to the error:
> $oLayer_shape = $oMap->getLayerByName("master");
> // $oShape = $oLayer_master->getFeature($oResult->shapeindex,-1); -Old
> getFeature method-commented out and replaced on next line:
> $oShape->draw($oMap,$oLayer_shape,$oImage); -fails on this line
> I do believe I'm retrieving a valid shape. What's even more confusing,
> I've had to replace the getFeature with getShape in other parts of the
> application and it seems to work.
Alan Boudreault
http://www.mapgears.com/
