[mapserver-users] shape->draw problem
Bistrais, Bob
Bob.Bistrais at maine.gov
Wed Jan 25 16:01:43 EST 2012
On further investigation, it looks like the query statement is the cause
of trouble. There appears to be some change in syntax in MS 6.x.
I've been trying to re-write it, but to no avail. Can anyone provide an
example for a query statement for a shapefile data source, something
like this:
$value = "some value";
$query = '("[MYITEM]" = "' . $value . '")';
-In particular, what should be or should not be quoted?
-----Original Message-----
Sent: Wednesday, January 25, 2012 10:28 AM
To: Alan Boudreault; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] shape->draw problem
Hi Alan,
I worked with the nextShape() a little bit as follows:
for ($i=0; $i<=($oLayer_master->getNumResults() - 1); $i++) {
while($oShape = $oLayer_master->nextShape()){
$oResult = $oLayer_master->getResult($i);
$oLayer_master->open();
$oShape = $oLayer_master->getShape($oResult);
$oShape->draw($oMap,$oLayer_shape,$oImage);
$oLayer_master->close();
That appears to have fixed the error message I was getting, but it still
does not draw results (it should).
You brought up a good point regarding the query. Here is the query
language, at least what I could find (it's worth noting I did not write
the application, but am now responsible to maintain it):
$query = $_GET['qpub'];
$query = '("[PUBCODE]" = "'.$_GET['qpub'].'")';
$oLayer_master->queryByAttributes("PUBCODE", $query,
MS_MULTIPLE);
pubExtent2($oLayer_master, $oMap);
From: Alan Boudreault [mailto:aboudreault at mapgears.com]
Sent: Sunday, January 22, 2012 5:41 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] shape->draw problem
Hi Bob,
I do not see any query in your code. Not sure why numresults return a
non-zero value. Check the example of the getShape() or nextShape()
functions in the documentation:
http://mapserver.org/mapscript/php/index.html#layerobj
Alan
On 12-01-20 03:55 PM, Bistrais, Bob wrote:
> I'm upgrading an application from Mapserver 5.6 to 6.0.1, PHP
MapScript.
> I'm having a problem with one section of code where it gives a
> shape->draw command. In MS 5.6, the Shape was derived from a
getFeature
> method, but in MS 6 this had to be changed to a getShape. The next
> command is to draw the shape. This returns the following error:
> Fatal error: Uncaught exception 'MapScriptException' in
> C:\ms4w_303\apps\mgs\htdocs\drawMap_detail_spatial.php:101 Stack
trace:
> #0 C:\ms4w_303\apps\mgs\htdocs\drawMap_detail_spatial.php(101):
> shapeObj->draw(Object(mapObj), Object(layerObj), Object(imageObj)) #1
> {main} thrown in
> on line 101
> Here is the code leading up to the error:
> $oLayer_shape = $oMap->getLayerByName("master");
> // $oShape = $oLayer_master->getFeature($oResult->shapeindex,-1); -Old
> getFeature method-commented out and replaced on next line:
> $oShape->draw($oMap,$oLayer_shape,$oImage); -fails on this line
> I do believe I'm retrieving a valid shape. What's even more confusing,
> I've had to replace the getFeature with getShape in other parts of the
> application and it seems to work.
Alan Boudreault
http://www.mapgears.com/
