[mapserver-users] mapcache
John Callahan
john.callahan at udel.edu
Thu Jan 26 13:30:38 EST 2012
I'm giving mapcache a try but with no luck. Well, some luck. The module
loads fine and the demo (vmap0, http://127.0.0.1/mapcache/demo/wms) also
works fine. I see the tiles being generated on disk. Great. However, the
problem comes in with my own data/services. A few questions may help me
determine the problem.
- in the source element, how do you define multiple layers? Comma
separated or separate <layers> entries?
- in the tileset element, can you have multiple grid entries? It doesn't
seem like it from reading the documentation but the sample tileset shows
both the "g" and "WGS84" grids.
- for cache type attributes, what are the possible values? The docs show
several possibilities (disk, sqllite, memcache) but the sample shows
type="tiff" which is not listed on the doc page. Can other file extensions
be used here?
- when I define a FORMAT with name and type, how does that get used? I see
that is called in the tileset but how does that relate to the image type
under getmap/params/format?
The doc page I am referring to is at
http://www.mapserver.org/trunk/mapcache/config.html. I'm sure I'll have
other questions as I work my way through. Thanks for this awesome addition
to Mapserver!
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120126/0060f1e8/attachment.html
