[mapserver-users] Re: getSymbol (): Symbol definition error.
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Jan 27 04:16:42 EST 2012
I may remember wrong but it may be that the template file must really exist and it can be otherwise empty but it must contain this magic string in the first line.
<!-- MapServer Template -->
-Jukka Rahkonen-
Francesc Cañas wrote:
> Ok, at first, thanks for helping me,
> But I feel lost, this is never ending story.
> I've removed all cartoline in the symbols.sym, I've removed
> the OUTPUTFORMAT
> block entirely but now i have a new error message:
> Content-type: text/html msReturnPage(): Web application
> error. Malformed
> template name (fooOnlyForWMSGetFeatureInfo)
> I thing maybe is because I didn't change the BROWSEFORMAT, so I do
> BROWSEFORMAT "image/png".
> For the fist time the screen don't display an error message, but don't
> display anything at all.
> The code now is like this:
> # Map file created from QGIS project file
> C:/Users/Francesc/Documents/Projectes_CAT_wgs.qgs
> # Edit this file to customize for your map interface
> # (Created with PyQgis MapServer Export plugin)
> MAP
> NAME "Projectes Cat"
> SIZE 100 100
> UNITS dd
> IMAGETYPE png
> EXTENT -9.569062 32.926808 6.763360 44.857479
> FONTSET 'C:/Users/Francesc/Documents/font/fonts.txt'
> SYMBOLSET 'C:/Users/Francesc/Documents/symbols/symbols.sym'
> PROJECTION
> 'proj=longlat'
> 'datum=WGS84'
> 'no_defs'
> END
> # Background color for the map canvas -- change as desired
> IMAGECOLOR 255 255 255
> # Legend
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> # Web interface definition. Only the template parameter
> # is required to display a map. See MapServer documentation
> WEB
> # Set IMAGEPATH to the path where MapServer should
> # write its output.
> IMAGEPATH 'G:/Francesc/ms4w/tmp'
> # Set IMAGEURL to the url that points to IMAGEPATH
> # as defined in your web server configuration
> IMAGEURL 'G:/Francesc/ms4w/tmp'
> # WMS server settings
> METADATA
> 'ows_title' 'Projectes Cat'
> 'ows_onlineresource'
> 'http://localhost/cgi-bin/mapserv.exe?map=C:/Users/Francesc/Do
cuments/Projectes_wgs84_v6.map'
> 'ows_srs' 'EPSG:4326'
> END
> #Scale range at which web interface will operate
> # Template and header/footer settings
> # Only the template parameter is required to display a map. See
> TEMPLATE 'fooOnlyForWMSGetFeatureInfo'
> END
> LAYER
> NAME 'Provincias_wgs84'
> TYPE POLYGON
> DUMP true
> TEMPLATE fooOnlyForWMSGetFeatureInfo
> DATA 'C:/Users/Francesc/Documents/SHP/Provincias_wgs84.shp'
> METADATA
> 'ows_title' 'Provincias_wgs84'
> END
> STATUS OFF
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'datum=WGS84'
> 'no_defs'
> END
> CLASS
> STYLE
> WIDTH 0.35
> OUTLINECOLOR 0 0 0
> END
> END
> END
> LAYER
> NAME 'Projectes_UTM31_wgs84'
> TYPE POINT
> DUMP true
> DATA 'C:/Users/Francesc/Documents/SHP/Projectes_UTM31_wgs84.shp'
> METADATA
> 'ows_title' 'Projectes_UTM31_wgs84'
> END
> STATUS OFF
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'datum=WGS84'
> 'no_defs'
> END
> CLASS
> STYLE
> SYMBOL "circle"
> SIZE 7.0
> OUTLINECOLOR 0 0 0
> COLOR 103 132 169
> END
> END
> END
> END
> http://osgeo-org.1560.n6.nabble.com/getSymbol-Symbol-definitio
> n-error-tp4340534p4342552.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
