[mapserver-users] Mapserver and TileCache, parsing error thereby no cached images
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Mon Jan 30 02:11:02 EST 2012
Perhaps it has something to do with newline characters?
[line 82]: '  type=WMS\n'
-Jukka Rahkonen-
Michael Markieta  wrote:
 Hi all,
Original question was posted here: http://gis.stackexchange.com/questions/19459/tilecache-and-mapserver-not-producing-images-and-raising-parsing-error
Just a forewarning, I will try to be as extensive with my question as possible. Due to a number of reasons why this might not be working, I have posted all sorts of portions of my debugging below.
Web map located here<http://rinnerweb.arts.ryerson.ca/moot2_dev>
Tile cache is being setup as a test run for the "hii_5" layer in OpenLayers. MapServer is the backend.
I am trying to get TileCache to cache images of my MapServer WMS. However, no images are produced. The TileCache is "trying" to load the tiles (as you can see on the live page), however, no images are returned.
When I follow the path<http://rinnerweb.arts.ryerson.ca/cgi-bin/tilecache.cgi?LAYERS=HII_railroads&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:3857&BBOX=-10592586.767623,5113378.756775,-9340242.496373,6365723.028025&WIDTH=256&HEIGHT=256> of one of the image tiles, I see this error:
An error occurred: File contains parsing errors: C:\ms4w\Apache\cgi-bin\tilecache.cfg
    [line 83]: '  url=http://141.117.104.183/cgi-bin/mapserv.exe\n'
    [line 84]: '  mapfile=C:/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map\n'
    [line 85]: '  extension=png\n'
    [line 86]: '  layers=HII_railroads\n'
  File "C:\ms4w\Apache\cgi-bin\TileCache\Service.py", line 85, in _load
    config.read(files)
  File "C:\Python27\lib\ConfigParser.py", line 297, in read
    self._read(fp, filename)
  File "C:\Python27\lib\ConfigParser.py", line 538, in _read
    raise e
  *   I've run a GetCapabilities<http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/moot2_dev/hii_railroads.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities> request and there are no warnings
  *   but GetMap<http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/moot2_dev/hii_railroads.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=HII_railroads&STYLES=&SRS=EPSG:3857&BBOX=-173.537,35.8775,-11.9603,83.8009&WIDTH=400&HEIGHT=300&FORMAT=image/png> request returns a blank page
  *   and the template<http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map&> return blank
Here are the relevant mapfile, tilecache.cfg, and openlayers source:
Not sure how much help I will get here, but the questions out there for anyone to take a stab at it!
hii_railroads.map
MAP                                                     #-> BEGIN MAP
    OUTPUTFORMAT                                        #-> BEGIN OUTPUT FORMATTING DEFINITION
        NAME "png"                                      # Name of format
        DRIVER AGG/PNG                                  # Image driver
        MIMETYPE "image/png"                            # Type of image
        IMAGEMODE RGBA                                  # Image mode
        EXTENSION "png"                                 # Image filetype
        TRANSPARENT ON                                  # Transparency
    END                                                 #-> END OUTPUT FORMATTING DEFINITION
    WEB                                                 #-> BEGIN WEB DEFINITION
        METADATA
            "wms_title"           "HII_railroads"
            "wms_onlineresource"  "http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map&"
            "wms_srs"             "EPSG:3857"
            "ows_enable_request"  "*"
        END
        TEMPLATE "template.html"
        IMAGEPATH "/ms4w/tmp/ms_tmp/"
        IMAGEURL "/ms_tmp/"
    END                                                 #-> END WEB DEFINITION
LAYER                                                   #-> BEGIN LAYER DEFINITION: Railroads <-#
    METADATA
    END
    NAME    HII_railroads                               # Layer identifier
    DATA    "data/wgs84/railroads_360.tif"              # Name of the data (in this case, string identifying a raster)
    STATUS  ON
tilecache.cfg
[HII_railroads]
  type=WMS
  extension=png
hii_5 = new OpenLayers.Layer.WMS("Railroads","../../cgi-bin/tilecache.cgi?",{
    layers:"HII_railroads",
    format:"image/png"},{
    isBaseLayer:false,
    transparent:true,
    format:"image/png",
    alpha:true,
    displayInLayerSwitcher:false
Michael Markieta - (416) 833 5581
Research Assistant - Department of Geography &
Bachelor of Arts Candidate - Geographic Analysis
Ryerson University
Toronto, ON, Canada
www.spatialanalysis.ca<http://www.spatialanalysis.ca>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120130/419948d3/attachment-0001.html
