[mapserver-users] Mapserver and TileCache, parsing error thereby no cached images
Michael Markieta markieta.m at gmail.com
Mon Jan 30 11:06:49 EST 2012
Which formatting is considered correct? Would this be the source of the
parsing error?
[HII_railroads]
  type=WMS
  url=http://141.117.104.183/cgi-bin/mapserv.exe
  mapfile=C:/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map
  extension=png
  layers=HII_railroads
or
[HII_railroads]
type=WMS
extension=png
*Note the indentation.
Michael Markieta - (416) 833 5581
Research Assistant - Department of Geography &
Bachelor of Arts Candidate - Geographic Analysis
Ryerson University
Toronto, ON, Canada
www.spatialanalysis.ca
On Mon, Jan 30, 2012 at 2:11 AM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi>wrote:
> Hi,
> Perhaps it has something to do with newline characters?
> [line 82]: '  type=WMS\n'
> -Jukka Rahkonen-
>  Michael Markieta  wrote:
>  Hi all,
> Original question was posted here:
> http://gis.stackexchange.com/questions/19459/tilecache-and-mapserver-not-producing-images-and-raising-parsing-error
> Just a forewarning, I will try to be as extensive with my question as
> possible. Due to a number of reasons why this might not be working, I have
> posted all sorts of portions of my debugging below.
> Web map located here <http://rinnerweb.arts.ryerson.ca/moot2_dev>
> Tile cache is being setup as a test run for the "hii_5" layer in
> OpenLayers. MapServer is the backend.
> I am trying to get TileCache to cache images of my MapServer WMS. However,
> no images are produced. The TileCache is "trying" to load the tiles (as you
> can see on the live page), however, no images are returned.
> When I follow the path<http://rinnerweb.arts.ryerson.ca/cgi-bin/tilecache.cgi?LAYERS=HII_railroads&FORMAT=image/png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:3857&BBOX=-10592586.767623,5113378.756775,-9340242.496373,6365723.028025&WIDTH=256&HEIGHT=256>of one of the image tiles, I see this error:
> An error occurred: File contains parsing errors: C:\ms4w\Apache\cgi-bin\tilecache.cfg
>     [line 83]: '  url=http://141.117.104.183/cgi-bin/mapserv.exe\n'
>     [line 84]: '  mapfile=C:/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map\n'
>     [line 85]: '  extension=png\n'
>     [line 86]: '  layers=HII_railroads\n'
>   File "C:\ms4w\Apache\cgi-bin\TileCache\Service.py", line 85, in _load
>     config.read(files)
>   File "C:\Python27\lib\ConfigParser.py", line 297, in read
>     self._read(fp, filename)
>   File "C:\Python27\lib\ConfigParser.py", line 538, in _read
>     raise e
>    - I've run a GetCapabilities<http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/moot2_dev/hii_railroads.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities>request and there are no warnings
>    - but GetMap<http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/apache/htdocs/moot2_dev/hii_railroads.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=HII_railroads&STYLES=&SRS=EPSG:3857&BBOX=-173.537,35.8775,-11.9603,83.8009&WIDTH=400&HEIGHT=300&FORMAT=image/png>request returns a blank page
>    - and the template<http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map&>return blank
> Here are the relevant mapfile, tilecache.cfg, and openlayers source:
> Not sure how much help I will get here, but the questions out there for
> anyone to take a stab at it!
> *hii_railroads.map*
> MAP                                                     #-> BEGIN MAP
>     OUTPUTFORMAT                                        #-> BEGIN OUTPUT FORMATTING DEFINITION
>         NAME "png"                                      # Name of format
>         DRIVER AGG/PNG                                  # Image driver
>         MIMETYPE "image/png"                            # Type of image
>         IMAGEMODE RGBA                                  # Image mode
>         EXTENSION "png"                                 # Image filetype
>         TRANSPARENT ON                                  # Transparency
>     END                                                 #-> END OUTPUT FORMATTING DEFINITION
>     WEB                                                 #-> BEGIN WEB DEFINITION
>         METADATA
>             "wms_title"           "HII_railroads"
>             "wms_onlineresource"  "http://rinnerweb.arts.ryerson.ca/cgi-bin/mapserv.exe?map=/ms4w/Apache/htdocs/moot2_dev/hii_railroads.map&"
>             "wms_srs"             "EPSG:3857"
>             "ows_enable_request"  "*"
>         END
>         TEMPLATE "template.html"
>         IMAGEPATH "/ms4w/tmp/ms_tmp/"
>         IMAGEURL "/ms_tmp/"
>     END                                                 #-> END WEB DEFINITION
> LAYER                                                   #-> BEGIN LAYER DEFINITION: Railroads <-#
>     METADATA
>     END
>     NAME    HII_railroads                               # Layer identifier
>     DATA    "data/wgs84/railroads_360.tif"              # Name of the data (in this case, string identifying a raster)
>     STATUS  ON
> *tilecache.cfg*
> [HII_railroads]
>   type=WMS
>   extension=png
> *index.html*
> hii_5 = new OpenLayers.Layer.WMS("Railroads","../../cgi-bin/tilecache.cgi?",{
>     layers:"HII_railroads",
>     format:"image/png"},{
>     isBaseLayer:false,
>     transparent:true,
>     format:"image/png",
>     alpha:true,
>     displayInLayerSwitcher:false
> Ryerson University
> Toronto, ON, Canada
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120130/9e193d51/attachment.html
