[mapserver-users] Avoid label overlaps
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Jun 24 12:53:29 PDT 2012
Andrea,
This is the way mapserver should work, so it sounds like a bug in trunk.
LABELCACHE ON shoudl be the default case and you do not need to
explicitly put it in the mapfile. Make sure you do not have FORCE ON on
any of your LABEL blocks as this make that label blind to the label
cache mechanism.
Ideally if you can make a trival mapfile that reproduces this and
include it in a bug, I'm sure someone will resolve it quickly.
-Steve W
On 6/24/2012 3:37 PM, Andrea Peri wrote:
> Hi,
> Is possible to force mapserver to avoid the overlaps of label of
> distinct layers ?
> I need to avoid the overlaps of all the label of the view.
> To have this
> I try to define the
> LABELCACHE ON
> on every layer
> and also
> POSITION AUTO
> and
> BUFFER 10
> but always I'm having some label of layer-A overlap other labels of layer-B.
> There is something I forgot ?
> I'm using the mapserver trunk version.
> Thx,
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org
