[mapserver-users] Avoid label overlaps
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jun 25 09:42:07 PDT 2012
Andrea,
Did you get this resolved?
Did you open a bug for it? What number?
We are starting the 6.2 release cycle and if this is an issue we need to
get it fixed.
Thanks,
   -Steve W
On 6/24/2012 3:53 PM, Stephen Woodbridge wrote:
> Andrea,
> This is the way mapserver should work, so it sounds like a bug in trunk.
> LABELCACHE ON shoudl be the default case and you do not need to
> explicitly put it in the mapfile. Make sure you do not have FORCE ON on
> any of your LABEL blocks as this make that label blind to the label
> cache mechanism.
> Ideally if you can make a trival mapfile that reproduces this and
> include it in a bug, I'm sure someone will resolve it quickly.
> -Steve W
> On 6/24/2012 3:37 PM, Andrea Peri wrote:
>> Hi,
>> Is possible to force mapserver to avoid the overlaps of label of
>> distinct layers ?
>> I need to avoid the overlaps of all the label of the view.
>> To have this
>> I try to define the
>>     LABELCACHE ON
>> on every layer
>> and also
>>     POSITION AUTO
>> and
>>    BUFFER 10
>> but always I'm having some label of layer-A overlap other labels of
>> layer-B.
>> There is something I forgot ?
>> I'm using the mapserver trunk version.
>> Thx,
>> Andrea Peri
>> qwerty àèìòù
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
