[mapserver-users] Mapserver WFS - ODBC RDBMS - GEOMETRY_COLUMNS and SPATIAL_REF_SYS Tables
Donald Kerr donald.kerr at dkerr.co.uk
Thu Mar 1 17:49:21 EST 2012
Hi List,
I have a point layer set up for WFS requests that connects to a Microsoft
Access database with two tables structured as follows:
Table: GEOMETRY_COLUMNS
Fields:
F_TABLE_NAME
F_GEOMETRY_COLUMN
GEOMETRY_TYPE
SRID
Values:
MyData
geom
POINT
27700
Table: MyData (Contains about 8,000 records)
Fields:
UniqueID
NameStr
Geom
XMIN
YMIN
XMAX
YMAX
Values:
1
Smiths
POINT(265377 665516)
265377
665516
265377
665516
In my layer, I have:
CONNECTIONTYPE OGR
CONNECTION "ODBC:overlays,FullOIs(geom)"
DATA "FullOIs"
A GetFeature request works well and quite speedily so I think that the the
query is run against the database is using the XMIN, YMIN, XMAX and YMAX
columns to restrict the data returned. During debugging, the following query
appeared in the response as recorded by Firebug in Firefox but I can't
replicate that (if anyone can tell me how to confirm that the BBox is being
used as follows that would be appreciated):
SELECT * FROM MyData WHERE XMAX > 176077.07205091 AND XMIN < 340988.92794909
AND YMAX > 583498.46091313 AND YMIN < 748311.53908687
The problem that I have relates to the GEOMETRY_COLUMNS table which I know
is not being used.
If I remove the geometry column from the connection string, i.e. change
CONNECTION "ODBC:overlays,FullOIs(geom)" to CONNECTION
"ODBC:overlays,FullOIs" - remove the word "(geom), it does not find the
geometry column from the GEOMETRY_COLUMNS table. It would appear that this
table is being completely ignored.
I have tried all sorts of combinations and field names and have also created
a SPATIAL_REF_SYS table with values that I use in a working PostGIS database
to no avail.
I previously used an OVF file but I think that may be limited to point
layers whereas, when I get this working as I want to, I would like to extend
this type of connection to line and polygon layers.
Can anyone advise please?
Many thanks.
Regards,
Donald
