[mapserver-users] [SOLVED] Re: MapServer 6.0.1 ignoring WMS options?
teknocreator
teknocreator at gmail.com
Mon Mar 5 20:10:17 EST 2012
[SOLVED]
Thanks for the replies, but first I apologize to Arman for not including the
commas in the BBOX request line. I was looking at the mapserver C code and
it's actually setup to handle either commas or spaces in the BBOX= option.
So it looks like I cut and pasted by attempt without commas here. My
initial attempts were with the commas and those also failed.
As to the second reply by Mike Smith of not using the "mode=map"...okay, I
see in the doc that it shouldn't be included in a WMS call. I tried that
for one of the point layers we've defined and it worked!! THANKS for
getting me further here!!
But the reason that I had it in there is that I had tried removing
"mode=map" with a raster layer that I'm also attempting to query. When I
tried to remove the "mode=map" there, I received an error:
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidSRS">
msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS must be
valid for all requested layers.
which doesn't make sense to me at the moment from what I can see in the doc
because the layer takes on the projection of the map if different.
When I put it back in, the error went away (still had the WMS request
issue). So, I wasn't sure where exactly to look here for the problem. But,
let me end this thread, read back up on working with raster data, and then
post in another topic thread if I'm still having problems. Thanks again!
Getting closer!
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapServer-6-0-1-ignoring-WMS-options-tp4549024p4549753.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
