[mapserver-users] Re: Run-time Substitution and Raster file problem
teknocreator
teknocreator at gmail.com
Sat Mar 17 07:43:21 EDT 2012
Thomas,
Thanks for the suggestion. And actually, the 'fhour_validation_pattern'
should be enclosed in the METADATA area above it. From what I've read, both
forms should work and we actually use the "*_validation_pattern" form in the
METADATA block to create an image of point values after a database select.
I did try what you suggested, though, taking that out of the METADATA and
using a VALIDATION block in the format you listed (and that's in the docs).
Unfortunately, same error occurs:
loadLayer(): Unknown identifier. Parsing error near (%):(line 90)
Doesn't get to the point where it tries to validate the RTS variable in the
mapfile. Can't seem to parse the DATA line with '%' in it when the type of
data is a raster.
Other thoughts?
Dave M
View this message in context: http://osgeo-org.1560.n6.nabble.com/Run-time-Substitution-and-Raster-file-problem-tp4626749p4627741.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
