[mapserver-users] Re: Run-time Substitution and Raster file problem
thomas bonfort thomas.bonfort at gmail.com
Sat Mar 17 07:48:43 EDT 2012
enclosing your data string with * seems wrong, what happens if you use quotes ?
On Sat, Mar 17, 2012 at 12:43, teknocreator <teknocreator at gmail.com> wrote:
> Thomas,
> Thanks for the suggestion.  And actually, the 'fhour_validation_pattern'
> should be enclosed in the METADATA area above it.  From what I've read, both
> forms should work and we actually use the "*_validation_pattern" form in the
> METADATA block to create an image of point values after a database select.
> I did try what you suggested, though, taking that out of the METADATA and
> using a VALIDATION block in the format you listed (and that's in the docs).
> Unfortunately, same error occurs:
> loadLayer(): Unknown identifier. Parsing error near (%):(line 90)
> Doesn't get to the point where it tries to validate the RTS variable in the
> mapfile.  Can't seem to parse the DATA line with '%' in it when the type of
> data is a raster.
> Other thoughts?
> Dave M
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Run-time-Substitution-and-Raster-file-problem-tp4626749p4627741.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
