[mapserver-users] ./mapserv: error loading shared libraries:
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Mar 22 17:25:01 EDT 2012
OK, then you probably need to add /usr/local/lib to you /etc/ld.so.conf
and run ldconfig after doing that.
-SteveW
On 3/22/2012 3:29 PM, Alberto Najera wrote:
> Hi
> ls -l /usr/lib/libjpeg* reports this after running ldconfig:
> ls: cannot access /usr/lib/libjpeg*: No such file or directory
> but we installed libjpeg in /usr/local/lib and not in /usr/lib
> and ls -l /usr/local/lib/libjpeg*
> reports all the jpeg installed files.
> Thanks
> Alberto Najera
> -----Mensaje original-----
> De: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] En nombre de Stephen
> Woodbridge
> Enviado el: jueves, 22 de marzo de 2012 12:07 p.m.
> Para: mapserver-users at lists.osgeo.org
> Asunto: Re: [mapserver-users] ./mapserv: error loading shared libraries:
> First thing run:
> sudo ldconfig
> and see if that fixes things.
> What does this report:
> -SteveW
> On 3/22/2012 1:13 PM, Alberto Najera wrote:
>> I am installing Mapserver in a Centos 5 distribution. All the
>> installation process seems to be done correctly, but after
>> running"make"in Mapserver and testing with ./mapserv we are getting
>> this error message:
>> ./mapserv: error loading shared libraries: libjpeg.so.8: cannot open
>> shared object file: no such file or directory
>> We have installed jpeg-8d to the default directories /usr/local/lib/
>> using the ./configure --disable-staticto make sure all the libraries
>> are shared.
>> Also, we are using gdal-1.9.0 and it is configured to use the external
>> jpeg-8d library.
>> I cannot understand why we are getting this error message.
>> Furthermore, I really do not need to use JPEG as I plan to use PNG
>> images for rendering our vector data.I have attempted to configure
>> Mapserver without JPEG by several means including not calling for it,
>> usingwithout-jpegand--disable-jpegand nevertheless, configure always
>> shows that JPEG support will be used.
>> Can you provide some help on how to fix this?I have been dealing with
>> this issue for over 10 days and cannot find a solution
>> Alberto Najera
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
