[mapserver-users] ./mapserv: error loading shared libraries:
Alberto Najera anajera at bicimapas.com.mx
Thu Mar 22 15:29:22 EDT 2012
Hi
ls -l /usr/lib/libjpeg*  reports this after running ldconfig:
ls: cannot access /usr/lib/libjpeg*: No such file or directory
but we installed libjpeg in /usr/local/lib  and not in /usr/lib
and ls -l /usr/local/lib/libjpeg*
reports all the jpeg installed files.
Thanks
Alberto Najera
-----Mensaje original-----
De: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] En nombre de Stephen
Woodbridge
Enviado el: jueves, 22 de marzo de 2012 12:07 p.m.
Para: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] ./mapserv: error loading shared libraries:
First thing run:
sudo ldconfig
and see if that fixes things.
What does  this report:
-SteveW
On 3/22/2012 1:13 PM, Alberto Najera wrote:
> I am installing Mapserver in a Centos 5 distribution. All the
> installation process seems to be done correctly, but after
> running"make"in Mapserver and testing with ./mapserv we are getting
> this error message:
> ./mapserv: error loading shared libraries: libjpeg.so.8: cannot open
> shared object file: no such file or directory
> We have installed jpeg-8d to the default directories /usr/local/lib/
> using the ./configure --disable-staticto make sure all the libraries
> are shared.
> Also, we are using gdal-1.9.0 and it is configured to use the external
> jpeg-8d library.
> I cannot understand why we are getting this error message.
> Furthermore, I really do not need to use JPEG as I plan to use PNG
> images for rendering our vector data.I have attempted to configure
> Mapserver without JPEG by several means including not calling for it,
> usingwithout-jpegand--disable-jpegand nevertheless, configure always
> shows that JPEG support will be used.
> Can you provide some help on how to fix this?I have been dealing with
> this issue for over 10 days and cannot find a solution
> Alberto Najera
