[mapserver-users] polygon symbol image fill problem
John Callahan
john.callahan at udel.edu
Thu Mar 29 09:05:17 EDT 2012
@Matt: I doubt I can use the standard symbol features of Mapserver. Maybe.
The hatch symbol is but one example. I have approx 10 - 20 image-based
fills of all different types. These were created for our published,
standardized geologic maps. Our web-based maps need to look identical to
our publications. Thanks for the suggestion.
@Havard: Thanks for the info. I'm glad there's a fix for this in 6.2. I
can wait until then.
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
On Thu, Mar 29, 2012 at 1:00 AM, Matt McClelland <matt at wildwalks.com> wrote:
> Hi John
> I can't answer you question specifically I have not tried that feature
> But can you use standard symbols to do the hatch-fill instead? You will
> probably get a better looking fill effect, and be kinder to your server
> The Symbol construction stuff took me a little while to get my head
> around, but it is very powerful and allows you to do some cool things.
> Hatching is fairly easy and you find a good example here.
> http://mapserver.org/mapfile/symbology/construction.html#hatch-fill
> Hope that helps
> Matt :)
> Matt McClelland
> mob: 0411 306 650
> e-mail: matt at wildwalks.com
> web: http://www.wildwalks.com/
> Books: http://www.wildwalks.com/books
> Newsletter: http://www.wildwalks.com/office/newsletters/
> On Thu, Mar 29, 2012 at 3:24 PM, John Callahan <john.callahan at udel.edu>wrote:
>> I hope this is an easy question. I'm drawing a polygon dataset through
>> WMS. For some of the classes, I am filling those polygons with a local PNG
>> file. However, the image itself has an outline. (see attached image for an
>> example) Is there a way to remove the symbol image outline inside my
>> polygon features?
>> Here is a snippet of my map file. I'm using Mapserver 6.0.2 on Windows
>> (I don't seem to remember this happening in older versions of Mapserver but
>> maybe I missed it.) Thanks.
>> CLASS
>> NAME 'pegmatite'
>> EXPRESSION 'pegmatite'
>> STYLE
>> SYMBOL 'graphics/pegmatite.png'
>> END
>> END
>> - John
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120329/07f00926/attachment.html
