[mapserver-users] nginx/fastcgi/mapserver
Peter Maes
thxftw at gmail.com
Fri May 11 04:42:58 EDT 2012
Hello,
I'm trying to run mapserver on nginx (fastcgi), but after 2 days booked
little success.
1. I've compiled mapserv with fastcgi support and validated this
2. I created a spawn-fcgi startup script based on this :
http://osgeo-org.1560.n6.nabble.com/Mapserver-on-nginx-td4226669.html
It now looks like this:
#!/bin/sh
MAPSERV_PORT=9001
USER=www-data
DAEMON=/usr/local/bin/mapserv
CHILDREN=5
# the -F switch of spawn-fcg does not work when the -n swich
# is set. using multiwatch instead
# see http://manpages.ubuntu.com/manpages/lucid/man1/spawn-fcgi.1.html
exec setuidgid $USER spawn-fcgi \
-a 127.0.0.1 \
-p $MAPSERV_PORT \
-u $USER \
/usr/bin/multiwatch -f $CHILDREN $DAEMON
In Nginx its called like this:
location /mapserver/ {
include /etc/nginx/fastcgi_params;
fastcgi_pass 127.0.0.1:9001;
fastcgi_param SCRIPT_FILENAME /usr/local/run/spawnscript;
fastcgi_param PATH_INFO /usr/local/run/ spawnscript;
When i try to connect to /mapserver in my browser, i get an error stating
502 Bad gateway.
So i tried starting the spawn script manually: /usr/local/run/spawnscript .
When i then try to connect using browser it works fine for a short while.
On the console it logs this error:
Spawing child[0] failed, next try
Child[1] died, respawn
Child[2] died, respawn
Child[3] died, respawn
Child[4] died, respawn
Child[0] died, respawn
Spawing child[1] failed, next try
Spawing child[2] failed, next try
Spawing child[3] failed, next try
Spawing child[4] failed, next try
Child[1] died to often, not forking again
Child[2] died to often, not forking again
Child[3] died to often, not forking again
Child[4] died to often, not forking again
Child[0] died to often, not forking again
After which the process exits and I revert to the 502 Bad gateway.
What am I missing here? :).
Thanks for any tips. I'm not that experienced with spawn-fcgi.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120511/24906e66/attachment-0001.html
