[mapserver-users] convert projection from UTM to WGS84 using proj
Murat Beyhan
beyhan at deprem.gov.tr
Wed May 16 04:41:39 EDT 2012
Dear friends,
I'm sorry, I'm not good at GIS applications but I wondering about
conversion between various projection or datum of the data files.
data.shp data.shx data.dbf and data.prj files are available.
shpdump data.shp gives following
Shape:0 (ArcZ) nVertices=4, nParts=1
Bounds:( 513275.786, 4006041.761, 0, 0)
to ( 513345.812, 4006078.182, 0, 0)
( 513275.786, 4006078.182, 0, 0) Ring
( 513301.130, 4006064.906, 0, 0)
( 513321.636, 4006053.249, 0, 0)
( 513345.812, 4006041.761, 0, 0)
data.prj as follows
PROJCS["(UTM)Universal Transvers Merkator 3�",GEOGCS["EUROPEAN
1950",DATUM["European_Datum_1950",SPHEROID["International",6378388.00000000,297.00000000],
TOWGS84[-87.00000000,-98.00000000,-121.00000000,0.00000000,0.00000000,0.00000000,0.00000000]],
PRIMEM["Greenwich",0.00000000],UNIT["Degree",0.01745329],AUTHORITY["EPSG","4230"]],PROJECTION["TRANSVERSE_MERCATOR"],
PARAMETER["SCALE_FACTOR",1.00000000],PARAMETER["CENTRAL_MERIDIAN",36.00000000],PARAMETER["LATITUDE_OF_ORIGIN",0.00000000],
PARAMETER["FALSE_EASTING",500000.00000000],PARAMETER["FALSE_NORTHING",0.00000000],UNIT["meter",1.00000000]]
using these data How to convert a file which is created using
european_datum_1950 to WGS84 (World Geodetic System 1984)
or where I have to start to understand these method of applications
using PROJ4.
Thanks
muratB
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
