[mapserver-users] convert projection from UTM to WGS84 using proj
Jørn Vegard Røsnes
jorn at spacetec.no
Wed May 16 05:21:22 EDT 2012
maybe something like this:
ogr2ogr -s_srs epsg:4230 -t_srs epsg:4326 <dest shapefile> <source shapefile>
http://www.gdal.org/ogr2ogr.html
kind regards
Jørn-Vegard Røsnes
----- Original Message -----
> From: "Murat Beyhan" <beyhan at deprem.gov.tr>
> To: "mapserver-users" <mapserver-users at lists.osgeo.org>
> Sent: Wednesday, 16 May, 2012 10:41:39 AM
> Subject: [mapserver-users] convert projection from UTM to WGS84 using proj
> Dear friends,
> I'm sorry, I'm not good at GIS applications but I wondering about
> conversion between various projection or datum of the data files.
> data.shp data.shx data.dbf and data.prj files are available.
> shpdump data.shp gives following
> Shape:0 (ArcZ) nVertices=4, nParts=1
> Bounds:( 513275.786, 4006041.761, 0, 0)
> to ( 513345.812, 4006078.182, 0, 0)
> ( 513275.786, 4006078.182, 0, 0) Ring
> ( 513301.130, 4006064.906, 0, 0)
> ( 513321.636, 4006053.249, 0, 0)
> ( 513345.812, 4006041.761, 0, 0)
> data.prj as follows
> PROJCS["(UTM)Universal Transvers Merkator 3�",GEOGCS["EUROPEAN
> 1950",DATUM["European_Datum_1950",SPHEROID["International",6378388.00000000,297.00000000],
> TOWGS84[-87.00000000,-98.00000000,-121.00000000,0.00000000,0.00000000,0.00000000,0.00000000]],
> PRIMEM["Greenwich",0.00000000],UNIT["Degree",0.01745329],AUTHORITY["EPSG","4230"]],PROJECTION["TRANSVERSE_MERCATOR"],
> PARAMETER["SCALE_FACTOR",1.00000000],PARAMETER["CENTRAL_MERIDIAN",36.00000000],PARAMETER["LATITUDE_OF_ORIGIN",0.00000000],
> PARAMETER["FALSE_EASTING",500000.00000000],PARAMETER["FALSE_NORTHING",0.00000000],UNIT["meter",1.00000000]]
> using these data How to convert a file which is created using
> european_datum_1950 to WGS84 (World Geodetic System 1984)
> or where I have to start to understand these method of applications
> using PROJ4.
> Thanks
> muratB
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
CONFIDENTIALITY
This e-mail and any attachment contain KONGSBERG information which may be
proprietary, confidential or subject to export regulations, and is only meant
for the intended recipient(s). Any disclosure, copying, distribution or use is
prohibited, if not otherwise explicitly agreed with KONGSBERG. If received in
error, please delete it immediately from your system and notify the sender
properly.
